Diff and Casings Breathers.
  • wanderinstar
  • Visitor
  • Visitor
30 Jan 2012 17:39 #32232 by wanderinstar
Diff and Casings Breathers. was created by wanderinstar
One of the next jobs I want to do is fit breather pipes to the diff and gearbox casings. I have seen some people screw fittings in. Is this an easy job. If not how secure are the bits of plastic pipe and jubilee clips?
  • myers647
  • Visitor
  • Visitor
30 Jan 2012 19:09 #32239 by myers647
Replied by myers647 on topic Re: Diff and Casings Breathers.
Hi mate , I bought my kit off ebay before it was available on this site. Its very easy to do, apart from the gear box and the transfer box which is just about impossible without removing it. Just mount the pipe ends in as high place as you can ie snorkel. Good important cheap mod.
Thanks
  • Dutchjimny
  • Visitor
  • Visitor
30 Jan 2012 20:43 #32252 by Dutchjimny
Replied by Dutchjimny on topic Re: Diff and Casings Breathers.
Is it easy to remove the transferbox and gearbox? maybe a howto?
  • supergaz
  • Visitor
  • Visitor
30 Jan 2012 20:43 - 30 Jan 2012 20:49 #32253 by supergaz
Replied by supergaz on topic Re: Diff and Casings Breathers.
Once the cap is prised off the diffs, then hose pipe will fit snug and tight, As supplied by Martin in the kits he supplies ( I have the same kit )
This is then reduced down with air hose couplings and air line to look tidy.
My SJ transfer case has had the breather drilled out, tapped and then a Air hose coupling screwed in, this is only possible with the casing opened up or the case will end up full of metal fragments.
Dutchjimny: The transfer case is easy to remove, but the gearbox is a big job.
Ian: Why don't you lower your transfer case down when you fit your KAP brackets? I'm sure the breather is the same as on the diffs so hose pipe will attach to it. The kits Martin has is perfect for the job.
Last edit: 30 Jan 2012 20:49 by supergaz.
  • wanderinstar
  • Visitor
  • Visitor
30 Jan 2012 21:50 #32260 by wanderinstar
Replied by wanderinstar on topic Re: Diff and Casings Breathers.
Yes Gary, will do that as I haven't fitted them yet. What sort of a job is gearbox. Can you get at it through top by removing gear lever gaiters?
  • 247sniper
  • Visitor
  • Visitor
31 Jan 2012 09:57 #32284 by 247sniper
Replied by 247sniper on topic Diff and Casings Breathers.
Jut a quicks guys, why would you want breathers on the duffs and gearbox ?
Steve.
  • wanderinstar
  • Visitor
  • Visitor
31 Jan 2012 10:20 #32285 by wanderinstar
So that when you go through water you dont get water going into diff,s and gearboxes,
  • adamatdraycott
  • Visitor
  • Visitor
31 Jan 2012 11:09 - 01 Feb 2012 06:36 #32308 by adamatdraycott
Replied by adamatdraycott on topic Re: Diff and Casings Breathers.
Basically if you go deeper than half the depth of your wheels, you could do with extending your breathers
Last edit: 01 Feb 2012 06:36 by adamatdraycott.
  • supergaz
  • Visitor
  • Visitor
31 Jan 2012 20:05 #32349 by supergaz
wanderinstar wrote: Yes Gary, will do that as I haven't fitted them yet. What sort of a job is gearbox. Can you get at it through top by removing gear lever gaiters?
Not done my gearbox :blush: Just diffs and transfer box, Not planning on going through much wet stuff as once i've got the jimny back together I want a year off spending on it. :whistle:
Next weekend will hopefully have the jimny complete minus painted all underneath.:)
31 Jan 2012 20:53 - 31 Jan 2012 21:26 #32363 by dirtydogz
Attachment Largedolphin.jpg not found
If you go in water that deep let me know as l won't to see that flipper.:evil:
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 31 Jan 2012 21:26 by dirtydogz.
The following user(s) said Thank You: Dutchjimny
  • Back in Black
  • Visitor
  • Visitor
01 Feb 2012 11:55 #32391 by Back in Black
Replied by Back in Black on topic Re: Diff and Casings Breathers.
Doesn't the gear box already have a breather pipe up in to the engine bay?? I'm fitting hose pipe breathers at the weekend and had only catered for the diffs and two on the transfer box.
Do I need another trip to BandQ for more stuff......?
  • Back in Black
  • Visitor
  • Visitor
01 Feb 2012 12:31 #32398 by Back in Black
Answered my own question by going and popping the bonnet - my Y reg 16v manual does NOT have a breather pipe to the engine bay from the gear box! Must have been looking at a different model before.
This isn't what I've got.........
Attachment 180px-Respiro_jimny_cambio.jpg not found
Back to B and Q......joy
Time to create page: 0.193 seconds
