Fuel treatment?.
- 247sniper
- Visitor
06 Jan 2012 17:44 #30160
by 247sniper
Fuel treatment?. was created by 247sniper
Do you guys use any form of fuel treatment/cleaner in your Jimny?
Steve.
Steve.
- ZookFastback
- Visitor
06 Jan 2012 17:48 #30161
by ZookFastback
Replied by ZookFastback on topic Re: Fuel treatment?.
Yep, I put a little bottle of Injector cleaner in once a month. I do about 4000k's/month and this seems to keep the injectors "Happy". Cheap at $2.99/bottle.
Also, once a year when I change the oil in diffs, gearbox and transfer case, I put a small amount of Nulon diff treatment in each case/diff.
06 Jan 2012 18:23 #30171
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Fuel treatment?.
Yes the same here, l use red x injector cleaner every second fill up.
2002 JLX Soft Top
07 Jan 2012 12:48 - 07 Jan 2012 13:57 #30207
by facade
Replied by facade on topic Re: Fuel treatment?.
Shouldn't be necessary.
But if you believe it works, put it in.
(I suspect that "injector cleaner" is a very expensive way to buy paraffin, likely with a squirt of cellulose thinners added for good measure)
EDIT not thinners, nail varnish remover
"Octane booster" is toluene (cellulose thinner)
"Magic cleaner additive" is acetone (nail varnish remover)
"fuel system cleaner/water remover" is isopropyl alcohol (tape head cleaner)
Last edit: 07 Jan 2012 13:57 by facade. Reason: to correct info
07 Jan 2012 19:43 #30223
by Foxtrot
Replied by Foxtrot on topic Re: Fuel treatment?.
Yes, I use red x injector cleaner
- adamjimny
- Visitor
08 Jan 2012 21:43 #30322
by adamjimny
Replied by adamjimny on topic Re: Fuel treatment?.
I use it before the MOT as emissions are usually high but this lowers it slightly.
But then mine isnt a daily driver so if its used regulary it wont be needed
Sent from my GT-I9100 using Tapatalk
- viciouspenguin
- Visitor
09 Jan 2012 09:43 #30343
by viciouspenguin
Replied by viciouspenguin on topic Re: Fuel treatment?.
personally i run high octane stuff from the pumps every now and then. one of them has cleaners i think, but i cant remember which brand so its a bit of potluck.
you can always do an italian clean; drive it all the way to the redline in each gear a couple of times :lol:
Sent from my Galaxy Nexus using Tapatalk
Time to create page: 0.171 seconds
