First gear sticky
- Chilgrove
17 Dec 2011 16:22 #28454
by Chilgrove
First gear sticky was created by Chilgrove
Does anyone else find engaging 1st gear a bit hit or miss? If I really concentrate on pressing the clutch hard down then there is not usually a problem but if I forget then often I find 1st has not properly engaged and it pops out. Any ideas, maybe there is some greasing I could do on the end of the gearstick?
Chilgrove
Chilgrove
- jo king
17 Dec 2011 17:03 #28463
by jo king
Replied by jo king on topic Re: First gear sticky
Sounds like your clutch cable is stretched. Maybe you should take up the slack you can do this by winding the plastic that goes into the gearbox. Thats what I would do first..
- r_ogilvy
17 Dec 2011 17:14 #28465
by r_ogilvy
Replied by r_ogilvy on topic Re: First gear sticky
mine grinds a bit when im going down to 1st gear when im moving, i have to let the revs drop down abit before.
- jo king
17 Dec 2011 17:24 #28469
by jo king
That sounds like a worn syncromesh for first is worn. I have a gear box if you would like one cheap cheap
- r_ogilvy
17 Dec 2011 18:24 #28477
by r_ogilvy
i might do that
18 Dec 2011 20:44 #28586
by kirkynut
Replied by kirkynut on topic Re: First gear sticky
You have to be nearly at a stop to get it into first in a JimJam but it shouldn't jump out of gear!
Time to create page: 0.098 seconds
