body lift
- nicho
- Visitor
17 Dec 2011 09:38 #28420
by nicho
body lift was created by nicho
elo i have just noticed dirtydogs 1inch body lift, iv seen the ally ones but nt the rubber ones before i like them coz they look like a factory fit pice, im after how many spacers ther are,how much are they. do you use the same bolts, any pics would be great,cant belive i never noticed it before dirtydogs. do you need anything else.a how2 would b good if anyone knows of one,
17 Dec 2011 10:40 - 17 Dec 2011 10:45 #28427
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: body lift
Hi nicho.
No you use the lower body rubbers cut down+ the factory nuts bolts and washers,all you need to do is make a bracket to lift the brake pipe junction up, and fit a longer nut +bolt in the hole to hold the junction to the bracket.
And it helps if you what to fit bolt on rock sliders on to the chassis.
hope this helps you.
DIERTYDOGZ
Attachment scan0005_2011-12-17.jpg not found
Attachment DSCF1154_2011-12-17.JPG not found
DIERTYDOGZ
2002 JLX Soft Top
Last edit: 17 Dec 2011 10:45 by dirtydogz.
The following user(s) said Thank You: nicho
- nicho
- Visitor
17 Dec 2011 10:56 #28428
by nicho
Replied by nicho on topic Re: body lift
o thanks thats great, it looks looks like 1.5inch on that pic have you measured it, i have not seen this mentioned all the time i have been on hear thanks again i can see this being done on a few jimnys now.
17 Dec 2011 12:18 - 17 Dec 2011 13:24 #28431
by dirtydogz
2002 JLX Soft Top
No l haven't it's just roughly measured it , the spring spacers are 1.5" + body lift of 3/4" come to 2"1/4"approx
with 205/70/15.+body lift@ spring spacers
with 205/75/15+body lift@spring spacers.
with jimnybits 2" lift only.
lf you would like to do this lift just go to my link.
Attachment DSCF1149_2011-12-17.JPG not found
Attachment DSCF1285_2011-12-17.JPG not found
Attachment DSCF1608.JPG not found
2002 JLX Soft Top
Last edit: 17 Dec 2011 13:24 by dirtydogz.
- zuki andy
- Visitor
17 Dec 2011 21:49 #28494
by zuki andy
Replied by zuki andy on topic Re: body lift
great job, a small body lift for free. i like it.
- nicho
- Visitor
18 Dec 2011 07:42 #28499
by nicho
in tbe last pic do u not have the body lift.
- nicho
- Visitor
18 Dec 2011 07:50 - 18 Dec 2011 07:55 #28500
by nicho
do the bolts go through the floor or are they part of the body, and dose anyone know how much the rubbers are to buy and were can you get them if ther cheep it might b worth buying sum and choping them all at once, i dont have a drive yet, will have in a few week hopefully when i move.o how many rubbers are ther thanks again
Last edit: 18 Dec 2011 07:55 by nicho.
18 Dec 2011 13:21 - 18 Dec 2011 13:25 #28518
by dirtydogz
2002 JLX Soft Top
No l remove the body lift when l fit the 2" spring lift ,as l didn't what to replace the back brake pipe, as it would be way too short with the body lift.
As for the body bolts they fixed to the body, l don't known how as you don't need to remove them,
Don't waste your money buying new rubbers as you can reuse the old ones mastic together under the washer as l did.
2002 JLX Soft Top
Last edit: 18 Dec 2011 13:25 by dirtydogz.
