kingpin bearings help
  • jamesey
24 Nov 2008 17:19 #277 by jamesey
kingpin bearings help was created by jamesey
hi ive got oil coming out of my passenger side front hub , im going to do my own kingpin bearings , but i need a few answers , ive got the model numbers of the bearings and the inner seal off the how to but , but do i need 2 bearings , top and bottom , also the bit i chisel out from the top where would i get one of those from and does that have a part no for it , also would i need a new seal that goes on the big ball thing at tha back as mine is leaking thick black grease out??? a full parts list for the job would be great then i can just print it out and ask the main bearing guys in sheffield and get them ordered , thanks:)
25 Nov 2008 07:56 - 25 Nov 2008 07:56 #279 by mlines
Replied by mlines on topic Re:kingpin bearings help
Jamesy,
The bearings come complete with the outer ring so you do not need to buy anything extra.
You really should change both the top and bottom ones at the same time.
If you buy a pair of these then they come complete - CLICK HERE
You will then need an axle oil seal - Click here
You do not need the bearing tool from Bits4Vits for Kingpin bearings, you only need this tool to change the wheel bearing, which is a different bearing.
You will also need some grease to put in the hub.
Last edit: 25 Nov 2008 07:56 by mlines.
25 Nov 2008 18:02 #280 by kirkynut
Replied by kirkynut on topic Re:kingpin bearings help
Hi there,
Do you not need to take the hub apart to remove the kingpin bearings and need to remove the wheel bearing to do this?
I've not taken the hub apart on my Jimny yet but can only imagine it's the same as on the SJ.
25 Nov 2008 18:12 #282 by mlines
No - if you are only doing the Kingpin bearings you do not need to undo the main wheel bearing.
See my guide HERE
  • mcjimny
29 Dec 2008 21:22 #326 by mcjimny
Replied by mcjimny on topic Re:kingpin bearings help
Forgive me if this is a real dumbass question, but those links above are they the exact parts i need?
I just didn't realise the bearings were so cheap and presumably they are better than the suzuki ones from the main stealer?
All help gratefully recieved.
29 Dec 2008 21:33 #327 by mlines
Yes - those are the correct Kingpin bearings. They are not better than the Suzuki ones but they are good quality branded (SKF) items so they are as good as the Suzuki ones. Suzuki tends to use the Koyo brand.
You can get them even cheaper than this if you are prepared to take a risk on unbranded Chinese bearings, but I have heard reports of them not fitting properly or failing quickly. The bearings in the link do fit!
Time to create page: 0.091 seconds
