Is the VVT engine worth it?
- 300bhpton
02 Dec 2011 12:16 #27053
by 300bhpton
Is the VVT engine worth it? was created by 300bhpton
I have driven a Jimny, which was a VVT powered one, I like it and thought it went better than a stock Tdi Landy.
But on reflection, a pre March 2001 Jimny would appear to cost less to tax, so is there really much real world difference between the non VVT and VVT engines?
I was thinking in terms of:
-off road performance
-on road performance
-mpg
-reliability
-tunability
Thanks
Matt.
-mpg
-reliability
-tunability
Thanks
Matt.
- goatboy
02 Dec 2011 12:28 #27054
by goatboy
Replied by goatboy on topic Re: Is the VVT engine worth it?
There is a few posts on here discussiing this very thing.
General opinion seems to be if you can afford a VVt then do, but there is not much in it.
Performance is slightly better (but only slightly), reliability seems similar, tunability is exceedingly limited for both.
One bonus of the VVT is its chain rather than belt driven so one less servicing cost.
- goatboy
02 Dec 2011 12:40 #27055
by goatboy
Have a look here... (knew it had been covered before)
bigjimny.com/index.php?option=com_kunena...=7&id=6745&Itemid=75
Worth noting if you go for later cars you may end up with a push button 4wd selector and ABS. Whether thats good thing or not is down to personal preference....
- 300bhpton
02 Dec 2011 12:43 #27056
by 300bhpton
Replied by 300bhpton on topic Re: Is the VVT engine worth it?
Thanks, hadn't realised about the belt vs chain. I did do a search, but maybe I didn't refine it enough to get useful results.
If there's not much in it, then I quite like the sound of cheaper road tax tbh.
02 Dec 2011 13:19 #27058
by Halford
Replied by Halford on topic Re: Is the VVT engine worth it?
the forum search function is pretty naff
best to use google and add site:bigjimny.com to the end of your search terms
i.e. vvt and non-vvt site:bigjimny.com
02 Dec 2011 15:59 #27070
by facade
Replied by facade on topic Re: Is the VVT engine worth it?
The hard top got the twincam engine with timing chain for X reg.
The dearer tax came in for Y reg.
Time to create page: 0.092 seconds
