Truck pulling to the right when braking!!
- jo king
- Visitor
Sounds like you need to check how much pad & shoe material there is, replace if worn to excess, give them a good bleed and make sure the sliders are free and the piston's not seized.
Probably seized sliders.
Dismantle it all, spray some good old WD40 under the rubber boot front and back of the sliders. Give it a few minutes to work then tap them from both directions until they move. Take care not to damage the rubbers and the ends of the sliders. Once they're out clean them up with some wet and dry and give them a good coat of something like 3 in 1 or better is a thin coat of copper ease. While you have it all apart if the pads are low or low enough to change them its a good time to as they're only cheap.
Check all you lines for splits and any unions for leaks and check your fluid level.
- goatboy
- Visitor
mcjimny wrote: thin coat of copper ease
Execpt don't use copper grease on the rubber bits, they won't like it eventually...
bigjimny.com/index.php?option=com_conten...drivechain&Itemid=37
- Gromit
- Visitor
- grumpy22
- Visitor
- supergaz
- Visitor
- jo king
- Visitor
supergaz wrote: I got a refurb kit from somewhere, about £30 both sides. Did the job no prob.
I think martins got a guide on here and got the bits from redbrake?
- supergaz
- Visitor
