New Jimny Owner.
  • wanderinstar
  • Visitor
  • Visitor
26 Nov 2011 00:11 #26603 by wanderinstar
New Jimny Owner. was created by wanderinstar
Hi,
I am just about to become a Jimny owner. What mods would you fit for off road work and possible some greenlaning.
Was thinking of these.
2" body lift
Decent set of tyres (any ideas)
Lock-Right Diff lock.
Ian.
  • supergaz
  • Visitor
  • Visitor
26 Nov 2011 08:32 #26606 by supergaz
Replied by supergaz on topic Re: New Jimny Owner.
Welcome to Bigjimny
What sort of money do you want to spend?
Maybe a 2" suspension lift will be better than body lift, this could be done with a full kit or just spacers to keep costs down.
If going big on tyres consider gearing = Rock Lobster = Expensive.
Will you do many road miles? Fitting some mods may make your jimny terrible on the road, Especially a Lock-Right diff lock.
  • viciouspenguin
  • Visitor
  • Visitor
26 Nov 2011 08:33 #26607 by viciouspenguin
Replied by viciouspenguin on topic Re: New Jimny Owner.
Hello & welcome,
you're about right with the mods, but I wouldn't bother with a difflock, thats cheating ;)
Greg
  • Nobby22
  • Visitor
  • Visitor
26 Nov 2011 08:43 #26608 by Nobby22
Replied by Nobby22 on topic Re: New Jimny Owner.
From my limited experience i would say one of the best things to get is a decent set of mud tyres. The Jimny is very capable from stock but wont be any good in the mud on road tyres as iam sure you know. They dont do your fuel economy any good so consider having them as a seperate set. 2" lifts are fine but most people sujust a 3" lift, HOWEVER you realy need to spend out more getting the car to drive ok and not lean over to one side. Such as corrected radius arms, longer panhard rods and brakelines. With a 2" lift you only realy need castor correction bushes put in the radius arms, this will give you back the self centreing off the steering. Apart from that it would just be new springs and dampers, and maybe a steering damper if you go for larger tyres. I surpose it will be down to your budget and how much work you want to do. Basically a 3" lift will cost more than a 2" lift.
I run Insa Turbo Sahara's in 215/75/15. I think this size is regarded as the biggest you can go with out having to start changing gear ratios. A 2" lift will allow you to run these with out the risk of them rubbing on the arches ( i think :blush: )
As for the Lock-right i have no experience of them, iam sure some one will give you the heads up on them.
Hope this helps ;)
Nobby
  • Nobby22
  • Visitor
  • Visitor
26 Nov 2011 08:46 #26609 by Nobby22
Sorry, when i said 2" lift i meant suspension lift not body lift. supergaz is probably right, better off with a suspension lift than a body lift.
  • r_ogilvy
  • Visitor
  • Visitor
26 Nov 2011 09:04 #26610 by r_ogilvy
Replied by r_ogilvy on topic Re: New Jimny Owner.
i would go for tyre size like nobby22 said, or 235/75/15. i have 31" with no rock lobster and it hardly moves :(
stay away from the body lift its a pain.
  • ShuDuck
  • Visitor
  • Visitor
26 Nov 2011 09:06 #26611 by ShuDuck
Replied by ShuDuck on topic Re: New Jimny Owner.
I agree on 2" suspension lift. I dont care for BL at all. With trailmaster lift you will improve the handling and ride as well fitting a bit bigger tires.
I have seen jimnys with 2" lift, 30" and 2x lockers outwheel anything
  • myers647
  • Visitor
  • Visitor
26 Nov 2011 09:57 #26614 by myers647
Replied by myers647 on topic Re: New Jimny Owner.
Hi mate and welcome,
I started off with just a set of A/T tyres and it went any where I wanted it to go they are a very capable little machine, you will be very surprised. I now have fitted a 2" KAP suspension lift with ES1000 shock absorbers, and i actually think its a lot smoother ride apart from the it feels like Im sailing a barge down the road.This is all you need to get to be honest in my opinion, but it all depends on how extreme you want to go & in most cases how big your pockets are. Im going to get some castor corrected front bushes and a steering damper as i use mine for a daily drive to work which is a 25 mile round trip because the wife has the nice car until the white stuff comes and then she wants the Jimny.
Hope this helps
James
  • darthloachie
  • Visitor
  • Visitor
26 Nov 2011 19:16 #26665 by darthloachie
Replied by darthloachie on topic Re: New Jimny Owner.
viciouspenguin wrote: Hello & welcome,
Greg
yes but it saves you breaking your radius arms :P :P
  • jo king
  • Visitor
  • Visitor
26 Nov 2011 20:04 #26682 by jo king
Replied by jo king on topic Re: New Jimny Owner.
HEAR HEAR darthloachie not a truer word spoken B)
27 Nov 2011 08:52 #26697 by kirkynut
Replied by kirkynut on topic Re: New Jimny Owner.
Greg
I don't understand this?
How have you been breaking your radius arms and how will a difflock save you doing so?
  • viciouspenguin
  • Visitor
  • Visitor
27 Nov 2011 10:41 #26708 by viciouspenguin
Greg
to cut a long story short.... click here
I doubt a difflock would have saved them.
