Lift kit
  • shootinginger@yahoo.co.uk
  • Visitor
  • Visitor
22 Nov 2011 16:20 #26302 by shootinginger@yahoo.co.uk
Lift kit was created by shootinginger@yahoo.co.uk
how long does it take to fit a 3inch pro comp lift kit?
springs
shocks
brack hoses
castor correctors bushes
panhard rods?
just a rought guess?
would i need anything else not getting new radius arms atm do to budget
  • supergaz
  • Visitor
  • Visitor
22 Nov 2011 16:42 #26308 by supergaz
Replied by supergaz on topic Re: Lift kit
Id guess no more than 3 hours if the castor correction bushes were already pressed into the arms. Getting the new polybushes in is easy, getting the old ones out without a press is a pain but possible. Id also consider rear shock brackets if not castor correcting the rear, or the bushes will get mashed.
22 Nov 2011 16:58 - 22 Nov 2011 16:59 #26310 by mlines
Replied by mlines on topic Re: Lift kit
Cutting off the corroded shock bolts.....
Cutting off the corroded radius arm bolts....
Cutting off the corroded panhard rod bolts....
Shearing off the brake connectors, making up new connectors and pipes
Trying to press out radius arm bushes...
Guess what I am doing!!!
Last edit: 22 Nov 2011 16:59 by mlines.
  • Dutchjimny
  • Visitor
  • Visitor
22 Nov 2011 17:00 #26311 by Dutchjimny
Replied by Dutchjimny on topic Re: Lift kit
I guess the longest bit is taking the radius arms off and get them repressed at a garage
  • Dutchjimny
  • Visitor
  • Visitor
22 Nov 2011 17:02 #26312 by Dutchjimny
@ martin : little offtopic but what sort of replacment bolts do you use? 8.8?
22 Nov 2011 17:14 #26313 by mlines
Yes 8.8
Available in BigJimny store!
  • Dutchjimny
  • Visitor
  • Visitor
22 Nov 2011 17:29 - 22 Nov 2011 17:41 #26318 by Dutchjimny
[strike]my "work van" peels out with bolts and nuts I bet my boss wouldnt even notice a few hundred missing :whistle:[/strike]
I see there metric fine and only have thread at the end maybe i can get them over here at the local store..
Last edit: 22 Nov 2011 17:41 by Dutchjimny.
  • supergaz
  • Visitor
  • Visitor
22 Nov 2011 18:25 #26323 by supergaz
mlines wrote: Cutting off the corroded shock bolts.....
Having fun in your MAN cave!!!!!:) :)
22 Nov 2011 18:32 #26327 by Halford
Replied by Halford on topic Re: Lift kit
:( wish I had a cave
22 Nov 2011 19:01 #26335 by mlines
Yes, having great fun!!
Remember this is the webstore that tells you how it is! Not some glorified Haynes manual guide along the lines of "undo this, undo that" when it really should read "lie under the car for hours, shear off the bolt head, crush your knuckles on a sticking out bracket when the socket strips the head!"
All bolts are now off from one side apart from the upper shock bolt. I am terrrifed of stripping or shearing the bolt as the other end appears to be a captive nut in an in-accessible area.
Been soaking it for a couple of days but it will not move, any ideas :(
  • supergaz
  • Visitor
  • Visitor
22 Nov 2011 19:05 #26337 by supergaz
Try soaking it in cola, it works like WD40, or its get some heat on it.
  • Dutchjimny
  • Visitor
  • Visitor
22 Nov 2011 19:09 #26339 by Dutchjimny
did you scare the bolt? give it a good wack with a hammer it could come loose
