Lower rear shock bolts...
- funkyjimny
Topic Author
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
01 Mar 2010 14:47 #2511
by funkyjimny
Lower rear shock bolts... was created by funkyjimny
Yet again ive lost a lower rear shock bolt, N/S of course.
Now does anyone know what thread the bolt is? If so I'm going to buy a length of studding and thread it in with a nylock on each end.
Gary
Gary
- ooky_123
01 Mar 2010 21:59 #2517
by ooky_123
Replied by ooky_123 on topic Re:Lower rear shock bolts...
NO idea sorry but have almost lost the N/S one myself. If you do find out, I would be tempted to do the same
- rjd1
01 Mar 2010 23:16 - 01 Mar 2010 23:17 #2520
by rjd1
Replied by rjd1 on topic Re:Lower rear shock bolts...
i drilled mine right through an used threaded rod
it was`nt up 2 the job so a mate used a coach bolt
easy fix
easy fix
Last edit: 01 Mar 2010 23:17 by rjd1. Reason: spellin lol
- Sutman
02 Mar 2010 05:43 #2522
by Sutman
Replied by Sutman on topic Re:Lower rear shock bolts...
I used a high tensile bolt, drilled through the shock mount and used a nylock nut
02 Mar 2010 07:06 #2525
Replied by mlines on topic Re:Lower rear shock bolts...
I used some 13mm studding having drilled out the mounts (the bolts had sheared in mine).
I think the original bolts are M12 Metric Fine (1.25mm)
- funkyjimny
Topic Author
- Moderator
02 Mar 2010 09:08 #2528
by funkyjimny
Replied by funkyjimny on topic Re:Lower rear shock bolts...
Thanks everyone, If i can find my thread gauges I'll check the pitch, but i too think they are M12x1.25. I think I'll order some studding and locknuts, if i have any left over I'll offer it for sale here to otheres.
Gary
Gary
Time to create page: 0.227 seconds
