will this fit for a steering damper??
  • myers647
  • Visitor
  • Visitor
30 Oct 2011 19:34 - 31 Oct 2011 12:31 #24837 by myers647
will this fit for a steering damper?? was created by myers647
No eBay APP ID and/or Cert ID defined in Kunena configurationHi will this be ok for a steering damper,to go with the bracket from bigjimny shop.
thanks
james
Last edit: 31 Oct 2011 12:31 by mlines.
30 Oct 2011 19:45 - 14 Dec 2011 19:15 #24842 by dirtydogz
No eBay APP ID and/or Cert ID defined in Kunena configurationThis one will be ok to uses
Hope this helps.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 14 Dec 2011 19:15 by dirtydogz.
  • Richard_J
  • Visitor
  • Visitor
31 Oct 2011 11:44 #24899 by Richard_J
Replied by Richard_J on topic Re: will this fit for a steering damper??
You will need to purchase the damper itself, I used a Land Rover Discovery Series 1 Steering Damper available from Ebay.
The BJshop quotes to use a Discovery 1 damper, the above poster has linked to a Defender damper which is different by having one ring end and one threaded end.
The Discovery 1 damper has threads on both ends.
31 Oct 2011 12:31 - 31 Oct 2011 12:32 #24902 by mlines
Richard is correct you need Pins (Threads) at both ends. The one in the ebay advert in the first posting is correct.
Last edit: 31 Oct 2011 12:32 by mlines.
  • myers647
  • Visitor
  • Visitor
31 Oct 2011 18:55 #24920 by myers647
Replied by myers647 on topic Re: will this fit for a steering damper??
cheers for the advice. i will get the one in the 1st post .
thanks
james
31 Oct 2011 20:39 #24931 by dirtydogz
No eBay APP ID and/or Cert ID defined in Kunena configurationYes your right this is the damper you need sorry.:(
