High Pitch Squeal
- hathome
- Visitor
29 Oct 2011 14:58 #24721
by hathome
High Pitch Squeal was created by hathome
Hi again all - Sure this is not related BUT have just changed the kingpins bearings and thought I'd take the Jimny out for a quick road test. After about 10 mins I've got this horrendous squeal form something !! OK when not moving so I thought maybe the clutch slipping - but seems ok getting up our steep drive and when testing with the handbrake on :blink: Is there anything obvious I should be looking for (Anything I may have done during the bearing change?) - Thanks for your help - I'd be lost without this site
- p1ngu32
- Visitor
29 Oct 2011 15:30 #24735
by p1ngu32
Replied by p1ngu32 on topic Re: High Pitch Squeal
anything gotten trapped between the disc and the back plate? stray nut or bolt? i get a huge squeel off mine when stones get wedged in there.
- martysmith
- Visitor
29 Oct 2011 15:37 #24738
by martysmith
Replied by martysmith on topic Re: High Pitch Squeal
may just be back plate toutching brake disc ........fingers crossed for you
- Dunkspeed
- Visitor
29 Oct 2011 15:45 #24741
by Dunkspeed
Replied by Dunkspeed on topic Re: High Pitch Squeal
I'd go for backplates too!
- hathome
- Visitor
29 Oct 2011 16:09 #24747
by hathome
Replied by hathome on topic Re: High Pitch Squeal
Thanks all - I'll check it out tomorow - If its not that I'll check the ancillory belts etc - its been sitting on the drive for a fortnight now going nowhere!
29 Oct 2011 16:19 #24751
Replied by mlines on topic Re: High Pitch Squeal
Simple check:
Drive belt slip - noise is related to engine rev level, rev the engine and see if it changes.
Drive train noise - road speed related, reving engine will not make a difference but speeding up /slowing down will.
- hathome
- Visitor
29 Oct 2011 16:38 #24757
by hathome
Martin - Good call
No noise on tickover or at revs - squeal only when on the move, but not all the time - prob around 20mph. I'll try and clarify tomorrow with a bit more info.
Cheers
Cheers
29 Oct 2011 19:15 #24763
by kirkynut
Replied by kirkynut on topic Re: High Pitch Squeal
I have the same thing but it must be different for you - mine's my Mrs!
29 Oct 2011 19:43 #24768
by Halford
Replied by Halford on topic Re: High Pitch Squeal
:lol: :lol: :lol:
mine's more of a whining drone than a squeal
- hathome
- Visitor
30 Oct 2011 11:00 #24782
by hathome
:laugh: :laugh: :laugh: :laugh: - No sounds like the same problem :laugh: :laugh: :laugh: :laugh:
- hathome
- Visitor
30 Oct 2011 14:04 - 30 Oct 2011 14:05 #24789
by hathome
Hi All
Had wheel off and back plate was Very Close - so bent this back a bit and crossed my fingers
BUT turns out its the alternator thats screaming its head off and you could fry eggs on it !! Can these be serviced or is it time to spend more money ??:evil:
Last edit: 30 Oct 2011 14:05 by hathome.
- Az1987
- Visitor
30 Oct 2011 14:15 #24792
by Az1987
Replied by Az1987 on topic Re: High Pitch Squeal
Poss wheel bearing?
Time to create page: 0.215 seconds
