MoT test shake-up - AutoExpress News
- Thank you received: 360
not sure if you've seen the news on Autoexpress - MoT test shake-up will leave motorists liable for astronomical bills to repair electronic stability control systems from next year
The Department for Transport will be required under EU law to test electronic stability control systems (ESC – also called ESP) in any car in which it is fitted, regardless of the date of manufacture or whether the system was an optional extra. And the cost to repair ESC can run into thousands of pounds.
Reader John Wilkinson, from Dunstable, Beds, was given a quote of £1,733 to fix the faulty system on his 2005 Vauxhall Astra.
If John chose not to fix it, his car would be judged ‘unroadworthy’ next year – even though it would be considered fit for the road had he chosen not to tick the £399 ESC option when he first bought the car.
And ESC isn’t the only technology that will be checked in MoT tests next year. Airbags, power steering, catalytic converters and factory-fitted tyre pressure monitoring systems will also be checked. You’ll find full details of the changes in next week’s Auto Express, released on 19 October 2011
Auto Express MoT test shake-up
- little jimny
- Visitor
- supergaz
- Visitor
By the way, does anyone want a car that will test every aspect of the new MOT? My Range Rover will be for sale shortly and already challenges the MOT tester because of the electronic handbrake and self levelling suspension.
-- Sent from my HP TouchPad using Communities
- supergaz
- Visitor
As a Commercial Brake tester engineer, I cannot see a safe way to test the electronic hand brake without ripping the brake shoes as class 4/7 is not an applied test except heavy stuff. Tapley test is to only safe way approved by vosa on a'lot of 4x4 systems however not very accurate.
The new nasty tool :sick: www.prosol.co.uk/new_products_r35/13_pin...or_mot_use_p2446.php
For the handbrake the problem is damage to the shoes but also the handbrake auto pulses. As the handbrake is actually an "e-brake" (Emergency Brake) it can be pulled on at speed to stop the vehicle (its quite impressive to do this by the way, LandRover demonstrator drivers do this as part of the "Experience"). When pulled on in this fashion it "pulses" on and off rapidly (a bit like ABS) which I understand the brake tester doesn't like.
Instead he took mine around the corner and tried it on a steep drive.
The problem with the suspension is that it goes into auto-extend mode and forces the wheels down to the extreme of their travel making it difficult to stop the wheel touching the ramp on some lifts. Then it is possible to confuse the system and it stays locked down. This means some people had to take it around to the dealers to have the suspension reset. The trick is to open a door or a boot before jacking the car up, this prevents the suspension from moving. I remember the surprise on the testers face the first time he did my Range Rover as the machine printed out a couple of pages of warnings before he started the test.
