Oil change(s)....
  • Back in Black
  • Visitor
  • Visitor
16 Oct 2011 13:51 #23765 by Back in Black
Oil change(s).... was created by Back in Black
I have just changed the engine, gearbox, transfer box and diffs oil, and as my 11 year old daughter would say OMG!!
What a difference fresh oil makes!! It's like a new car. Spark plugs next.....
Not all good news though, whilst struggling about underneath I noticed I definitely need a new back box and quite a bit of Wagtail damage to various dangling down bits. Need some protection down below (oh err). Also must sort the rear towing things - one took a beating/bending at wagtail. Need a proper tow/recovery bar.
  • doncarlyon
  • Visitor
  • Visitor
16 Oct 2011 14:06 #23766 by doncarlyon
Replied by doncarlyon on topic Re: Oil change(s)....
My mate knocked up a couple of rear recovery points that clamp to the rear chassis leg and they are spot on. Or i think you can buy one in the shop on here.
  • Back in Black
  • Visitor
  • Visitor
16 Oct 2011 14:21 #23769 by Back in Black
Replied by Back in Black on topic Re: Oil change(s)....
Thanks for that I'll check the shop out.
At wagtail someone had a bar across the rear with D's on either end, which I presume is also attached to the chassis.
  • darthloachie
  • Visitor
  • Visitor
16 Oct 2011 15:38 - 16 Oct 2011 15:42 #23774 by darthloachie
Replied by darthloachie on topic Re: Oil change(s)....
Back in Black wrote: I have just changed the engine, gearbox, transfer box and diffs oil, and as my 11 year old daughter would say OMG!!
oops sorry :blush: :)
Last edit: 16 Oct 2011 15:42 by darthloachie.
  • darthloachie
  • Visitor
  • Visitor
16 Oct 2011 15:46 - 16 Oct 2011 15:57 #23775 by darthloachie
Back in Black wrote: Thanks for that I'll check the shop out.
could have been us- it was a towbar with recovery shackles welded on each end
Attachment rear.jpg not found
Last edit: 16 Oct 2011 15:57 by darthloachie.
  • Back in Black
  • Visitor
  • Visitor
16 Oct 2011 16:25 #23783 by Back in Black
Yep that's the sort of thing, is it attached to the towing points or chassis proper? Ideally I'd like something similar with the D's and a removeable tow hook.
There's no need to say sorry. It wasn't your fault I a) got stuck and b) wasn't prepared AND you did get me out (thank you for that). If I had proper recovery points you'd have had an easier time getting me out.
  • darthloachie
  • Visitor
  • Visitor
16 Oct 2011 20:21 #23803 by darthloachie
is a proper towbar attached to the chassis
it also has a plate welded between the two arms going back to the chassis so it can be used to mount a rear winch
there are more piccies of it here
www.bigjimny.com/index.php?option=com_ku...4373&Itemid=75#14386
18 Oct 2011 18:43 #23973 by kirkynut
Replied by kirkynut on topic Re: Oil change(s)....
I use a tow bar as my rear recovery point with a dirty great metal ring welded to it proper which still allows me to attach my tow ball for the future when I plan to tow a camping trailer rather than carry the weight in the motor!
I put it nose down a rather steep bank recently and got winched out backwards off it and it didn't flinch!
  • Back in Black
  • Visitor
  • Visitor
19 Oct 2011 10:08 #24015 by Back in Black
Excellent - thank you for the feed back. Mrs Black in Black has "offered" to buy me a rear tow bar for my birthday (she just doesn't know it yet :whistle: ) - I'm browsing ebay for a towbar.
Once I have the basic bar in place I can do as suggested and get extras attached to enable easier/more robust rearward recovery. With the added bonus of a removeable tow ball thingy should the need arise.
Time to create page: 0.158 seconds
