Tree sliders
- ajs850
15 years 1 month ago #23527
by ajs850
Tree sliders was created by ajs850
HI does anybody know where i can get some good quality tree sliders?
Thanks
Andrew
Thanks
Andrew
15 years 1 month ago #23528
by Halford
Replied by Halford on topic Re: Tree sliders
Hi Andrew
I think most people have to make their own as the ones that are available tend to be simply side steps and even then I wouldn't let anything heavier than my dog step on them
don't know if you've seen this www.4x4community.co.za Rockslider thread
15 years 1 month ago - 15 years 1 month ago #23532
by Obarno
Replied by Obarno on topic Re: Tree sliders
KAP Suzuki sell some good quality rock sliders. They are weld on but good enough to high lift off.
Just found a photo of mine
Last edit: 15 years 1 month ago by Obarno.
- vitara_mad
15 years 1 month ago #23546
by vitara_mad
Replied by vitara_mad on topic Re: Tree sliders
don't know of any that are good quality bolt on & the way i see it is why would anyone buy some that you have to weld on yourself it just sounds so silly to me cus if you are capable of welding them on you should be capable of making them yourself so no point paying someone else to make them
15 years 1 month ago #23548
by Obarno
As I understand, its difficult to make bolt/clamp on rock sliders because of the proximity of the floor to the chassis, and also on the drivers side because of the amount of pipework that runs down the inside of the chassis. So weld on ones are a good way of providing the solution. However if you neither have the skills nor equipment to weld them on youself, but know somebody that has, then these are a good solution.
- vitara_mad
15 years 1 month ago #23568
by vitara_mad
bolt on ones would be fine with a body lift.
as you said above if you know someone who can weld then you could weld some on but still no point buying some that weld on as you could just get your welder to knock them together as well
Time to create page: 0.099 seconds
