First Mods
  • happypig
  • Visitor
  • Visitor
10 Oct 2011 11:42 #23412 by happypig
First Mods was created by happypig
My Jimny is standard, with the exception of ATs. What would the collective advise as first upgrade ?
I'm thinking of (in no particular order):
New alloys with road wheels for general use (to be swapped with steel rims/ATs for pay and play/green lanes)
Snorkel (getting stuck in rather deep water at Slindon was a bit of a worry)
Welded recovery points.
10 Oct 2011 12:43 #23415 by kirkynut
Replied by kirkynut on topic Re: First Mods
I don't wish to stick my nose up at your AT tyres but I would consider those as my road tyres and make my first upgrade a suspension lift with a view of a further upgrading the tyres to larger MT's.
Then will come the winch bumper and winch and .........
As for a snorkel, you don't have to drive through water and you'll soon get sick of the maintenance it causes! Can't think of any water at Slindonia that needs a snorkel. The money saved on not buying a snorkel could buy most of a set of 3" lifting springs and shocks - maybe from Martin soon by the sounds of it!
If you are addicted to water though, as it does draw some people to it as much as it makes me avoid it, a snorkel is cheaper than a bent con rod after the engine has hydrauliced!
Some river/Ford crossings on greenlanes can need one in winter but again I wouldn't do the crossing.
10 Oct 2011 13:17 #23419 by mcjimny
Replied by mcjimny on topic Re: First Mods
1. Improve the recovery points
2. Good recovery gear, straps/strops and d shackles
3. Lift
4. Better tyres(as above keep the AT's for the road)
  • myers647
  • Visitor
  • Visitor
10 Oct 2011 13:40 #23420 by myers647
Replied by myers647 on topic Re: First Mods
Hi mate and welcome,
as the others have advised, get yourself a lift kit and some A/T tyres and it will go almost any where then the rest will come in time.
good look
james
  • Dutchjimny
  • Visitor
  • Visitor
10 Oct 2011 14:15 #23423 by Dutchjimny
Replied by Dutchjimny on topic Re: First Mods
Is a 4.5"lift road drivable?
10 Oct 2011 18:06 #23444 by kirkynut
There are a few people on here with 4.5" lifts who I think are happy with them and use them on the road. The only thing is, the higher you go, the wider you need to go to maintain stability.
Then you need to make your arches wider to cover your tyres and do some body cutting to stop them catching.
I wonder what a lift that high is like on a side slope?
I considered it but will be sticking with 3".
10 Oct 2011 18:56 #23448 by mcjimny
kirkynut wrote: There are a few people on here with 4.5" lifts who I think are happy with them and use them on the road. The only thing is, the higher you go, the wider you need to go to maintain stability.
Isn't generally a rule that for every inch you go up you should go the same in width?
Therefore on a 4.5 inch you'd need 10inch wide rims.........technically? But then you would also be running taller tyres.....................................
All that considered i'd want a cage!! Surely it would have a propensity to fall over?
  • myers647
  • Visitor
  • Visitor
10 Oct 2011 19:21 #23450 by myers647
if you want some good strong heavy duty recovery points that you weld on i can get you some made for £22 including P&P. just let me know.
thanks
james
10 Oct 2011 19:24 - 10 Oct 2011 19:24 #23451 by mcjimny
myers647 wrote: if you want some good strong heavy duty recovery points that you weld on i can get you some made for £22 including P&P. just let me know.
thanks
james
tell me more......
Last edit: 10 Oct 2011 19:24 by mcjimny.
  • myers647
  • Visitor
  • Visitor
10 Oct 2011 19:36 #23453 by myers647
Hi mate i have them on the front of mine they are very strong thick steel that i had welded onto the original towing eyes i cut my bumper a little so they look very neat and tidy..
thanks
james
  • happypig
  • Visitor
  • Visitor
11 Oct 2011 04:28 #23465 by happypig
Replied by happypig on topic Re: First Mods
thanks
james
Very interested, got any pics so I can see what they look like ?
  • Sandez
  • Visitor
  • Visitor
11 Oct 2011 08:23 #23474 by Sandez
Replied by Sandez on topic Re: First Mods
Not a mod that helps performance, but I would strongly recommend a steering damper for improved comfort and control
