Fitted a pair of roof lights today...
  • DVs-Jimny
  • Visitor
  • Visitor
15 Sep 2011 19:11 #21957 by DVs-Jimny
Fitted a pair of roof lights today... was created by DVs-Jimny
Next job, wire 'em up :)
  • Nobby22
  • Visitor
  • Visitor
16 Sep 2011 17:42 #21999 by Nobby22
Replied by Nobby22 on topic Re: Fitted a pair of roof lights today...
Hey nice. ;) If you get a chance can you show us how you wire it up? I am thinking of getting some of these my self.
Nobby
16 Sep 2011 19:12 #22012 by MigCooper
that looks nice :) do you have some more pics of the roof rack? is it the sort of ones you can get in halfords?
Snorkel and plenty of rust to be treated :)
  • sully
  • Visitor
  • Visitor
17 Sep 2011 07:07 #22031 by sully
Replied by sully on topic Re: Fitted a pair of roof lights today...
looks nice mite get some myself how you wiring them upB)
  • happypig
  • Visitor
  • Visitor
17 Sep 2011 18:14 #22055 by happypig
Replied by happypig on topic Re: Fitted a pair of roof lights today...
I'm tempted to fit some on mine. I was thinking of removing the interior light and fabricating a console with the light switches (and the interior light) in it.
  • Mumbo Jimbo
  • Visitor
  • Visitor
17 Sep 2011 18:17 #22057 by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: Fitted a pair of roof lights today...
Looks good, I'd like to fit some myself but can't see a neat way to pass the wiring to the interior. Was thinking of using the channel down the A-Pillar where the aerial wire goes?
  • X-Eng Simon
  • Visitor
  • Visitor
19 Sep 2011 07:20 #22116 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Fitted a pair of roof lights today...
I helped someone wire up lights on a Discovery 4 - which he definitely didn't want to drill holes in!
Our solution was to use insulated copper foil tape, similar to this: www.jpleisure.co.uk/item71017.htm , but 5mm wide. A single strip over a couple of feet would handle 10A without heating up noticeably. We just ran two (live & earth) per lamp.
The terminations are also self adhesive foam backed with screw terminals. We ran this from the edge of the light bar, through the door jam under the sealing rubber and terminated it inside the headlining. He stuck Vinyl (that you use for signs) over the top which was an approximate colour match - and the whole thing was invisible and non damaging.
Si
19 Sep 2011 08:06 #22117 by mcjimny
I was going to go down the a pillar but i'm waiting until i get a snorkel on to run the wires behind.
19 Sep 2011 12:43 #22127 by Mud_Muppet
Oh ill post some pics up of my spot light install, used Halfords roof bars then mounted 4 wipac spot lights up front and 2 wipac work lights at the rear for reversing and recoverys, also mounted my waffle boards on the bars aswell, look quite good if i might say so (ill post pics soon)
As for the wiring ran all the wining along the standard roof bars down into the rear door under the rubber seal, then along the drivers side behind the rear panel under the seat to my switches near the gear stick... Top job if i say so, all is linked live to the battery with a HUGE fuse lol
Cheers Dan
2001 Red Tin Top,
4.5 inch ORA lift kit,
Pro Comp steering damper
Kap Winch Bumper,
White Weller offset Rims with 30" Insa Turbo Special Tracks,
CB Radio,
Stripped Interia
Roof Rack with 4 front Wipac,
Rear Wipac recovery Lights
.....Plenty more on its way !!!!
