Vitara and Jimny Wheels
  • teafortwo0789
18 Aug 2011 13:53 #20636 by teafortwo0789
Vitara and Jimny Wheels was created by teafortwo0789
Are Vit wheels and Jimny direct replacements? Help
  • little jimny
18 Aug 2011 14:20 - 18 Aug 2011 14:21 #20638 by little jimny
Replied by little jimny on topic Re: Vitara and Jimny Wheels
I think I'm right in saying you mean the early Vitara wheels rather than the Grand Vitara wheels, ie these
The seller of these had them on his Jimny and didn't even realise they were Vitara wheels, so I think you'll have no trouble fitting them but I don't know if they have the same offset. Even if the offsets were different you'd be OK if you used matching pairs on each axle. The only other thing to bear in mind would be tyre size. The Jimny comes with 205/70/15 as standard, I'm not sure what are fitted to those Vitara wheels (could be 195/80/15). You can use a tyre calculator (just google to find one) to see if there's much difference in rolling circumference.
For what its worth, if those wheels weren't so far away I'd have snapped them up at the £40 asking price.
Last edit: 18 Aug 2011 14:21 by little jimny.
  • teafortwo0789
18 Aug 2011 14:44 #20639 by teafortwo0789
Replied by teafortwo0789 on topic Re: Vitara and Jimny Wheels
Hi, thank you for the info'. It's not the tyres I'm interested in it is the wheels. I will be replacing the tyres. I need 6 wheels in total and already have 4, so I need them to match.
18 Aug 2011 21:52 #20664 by kirkynut
There's not much in it but they have a lesser offset than Jimny wheels. About 5mm I think from memory. So although they'll fit, Jimny ones are much better.
