Rock Lobster or other reduced ratio boxes
  • ooky_123
10 Jan 2010 17:52 #1830 by ooky_123
Right, a Mate has just stuck a set of 31x10.5x15's on his sports track and it looks HUGE !!!
So much so .. I want a set... but given the 215rx15's are pushing teh standard gearing to the limit, and I really donot have the time to source and build a TX box, what is the easiest option .... Im happy to part with money if it gets me to my goal
Can they be bought ? how easy is it to sourse the bits and getone built / build it yoruself ?
Ive seem Martin's How to guide and I dont have the time or space to attempt anything like that.
A Bolt on ... away you go solution is I guess what im looking for ..
Anyone ?
  • Baz2236
10 Jan 2010 19:56 #1831 by Baz2236
Replied by Baz2236 on topic Re:Rock Lobster or other reduced ratio boxes
Rs manafacturing does a full bolt on sj kit or you can get some trial jimny gears put into your t box. Thus keeping orginal speedo drive and props etc. And not fitting an old sj box.
Let me know how you get on cos I am looking todo the same very soon.
Baz
10 Jan 2010 20:09 - 11 Dec 2010 18:16 #1832 by mlines
I was not personally happy with the special Low Ratio Jimny gearset fitted to my Jimny
I believe mine had had a chain replaced (by changing the transfer box) before I got it and I had to do the same shortly after I got it. The chain slipped badly. The Special Low Ratio Jimny gearset people suggest you should fit a new chain at the time of putting the new gears in but at over £300 this makes it a very expensive option.
A Rocklobster is quite cheap and easy to make, you need to get hold of two transfer boxes, one from a 413 and one from a 410. The 410 ones are getting rarer and more expensive. Then for about £100 you can get the gears cut and swapped.
Rebuilding the transfer box is quite easy despite the apparent long list of steps in my guide.
If you then fit a commercial adaptor kit (Off-Road Armory or -Rob Storr) it becomes a pretty much bolt on solution.
Last edit: 11 Dec 2010 18:16 by mlines.
  • jonplace
14 Jan 2010 17:25 #1852 by jonplace
Replied by jonplace on topic Re:Rock Lobster or other reduced ratio boxes
i went down the rob storr route and cant fault it. refurbed box with machined gears, not cut / shut. new bearings too
i paid extra to get the full bucket style fitting kit, totally solid bit of kit, could probs jack the car up off the tbox now. i also bought some poly bushes as the standard ones are a nightmare to work with. seriously the best money i've spent on the car.
  • s2quattroturbo
14 Jan 2010 22:15 #1853 by s2quattroturbo
Replied by s2quattroturbo on topic Re:Rock Lobster or other reduced ratio boxes
that looks like a serious piece of kit the plate it is mounted on... think you could easy jack the car on it. bet you cant wait to get out there and try it.
  • ooky_123
15 Jan 2010 07:51 #1856 by ooky_123
Replied by ooky_123 on topic Re:Rock Lobster or other reduced ratio boxes
Wow .... Gimmi gimmi gimmi ......
Can I ask how much ?
I tried to email Rob but the mail bounced.
Im out of teh country at present, but will certainly try and chase him up when I return
Time to create page: 0.306 seconds
