4WD Speed
- daly443
26 Dec 2009 11:22 #1694
by daly443
4WD Speed was created by daly443
This may seem like a daft question, but here we go:
Does anyone know what speed you can do in 4 wheel drive ? I have read several articles and they suggest that you can only really crawl in 4wd.
The problem we have is that our Jimny will go into 4 wd easily enought, but is difficult to get out of 4wd. I have read on other threads here, that if the car is rocked or moved forward then more often that not, you can select 2wd again.
As this is my wifes car, she wants to use 4wd around the snowy / icy sidestreets, but is worried that when she gets to the gritted main roads, then she will not be able to get our of 4WD.
The other question is it possible just to leave in 4WD for normal road journeys permanently
Cheers
Paul
Cheers
Paul
26 Dec 2009 12:00 #1695
Replied by mlines on topic Re:4WD Speed
No - don't drive on the roads in 4WD, you will wind up the transmission. At best it becomes impossible to get back into 2WD at worst you break something really expensive.
There are two types of 4WD systems (leaving aside odd technical variations), permanent and part-time.
Permanent systems, such as that fitted to most modern 4x4s like Range Rovers, including a central differential. This central differential allows the front wheels and rear wheels to rotate at different speeds, allowing all 4 wheels to be driven by the engine without stresses building up in the system.
Part-time 4WD, as fitted to the Jimny, does not have this central differential, therefore the front and rear wheels have to rotate at the same speed. This builds up stress in the system that is normally relieved by the wheels slipping on a rough surface (off-road). On road the wheels do not slip and stress builds up until something breaks.
Why do the front and rear wheels have to rotate at differenrt speeds?? Drive your car on a surface that "marks" turning a circle and look at the tracks you have left, the rear wheels have not follwed the same tracks as the front, they have travelled a difference path/distance therefore needed to rotate a a slightly different speed.
So do not use 4WD on a grippy surface
- wildfire
28 Dec 2009 19:48 #1724
by wildfire
Replied by wildfire on topic Re:4WD Speed
This has always has puzzled me as the manual as you can put it into 4x4 upto 60 mph.
I have left it in 4x4 for a long time (20 miles) by accident, after dealing with a very slippy wet section of road around here. Nothing bad happened apart from locking up when i was trying to reverse after parking.
But this was before i learnt about diff windup, so i tend to be more careful now days. Live and learn.
- ooky_123
29 Dec 2009 08:34 #1725
by ooky_123
Replied by ooky_123 on topic Re:4WD Speed
I regularlky slip it into 4WD when driving .. 40 mph or so just to make sure everything is working ./.. the light comes on and the hubs "Ping" into position. do a mile or so and thenslip it out again.
If were in heavy traffic I put it into low range and crawl, occasionally driving up to 4th before looking for an opportunity to stop and putit back in high range. Generally though, I always make sure teh wheels are straight as to avoid windup ... where possible
Jason
Jason
- daly443
18 Jan 2010 18:30 #1931
by daly443
Replied by daly443 on topic Re:4WD Speed
Excellent - Thanks for the advise.
I used 4WD in the aftermath of the latest snow fall, when the roads turned to ice - it certainly did the trick and we reached when others couldnt..
- Baz2236
19 Jan 2010 15:55 #1942
by Baz2236
Replied by Baz2236 on topic Re:4WD Speed
This had often confussed me I drove mine jimny about in the snow for ages in 4wd high some times up to 50. In low box I don't go to fast on the road unless it's slippery.
But now any again there is a flood near me it floods across the road and is about a mile long and I always drive that in low box as it's get about 3ft deep in places
