Clunk/Clang - when in 4Low .
- Thank you received: 115
23 May 2011 11:49 #16831
by maverick
Jalapeño, IISY?
Clunk/Clang - when in 4Low . was created by maverick
I've gotta an occassional LOUD clunk/clang coming from T-case area when in 2 or 4Low and driving up punishing sections.
I've looked underneath, and all T-case rubber mounts are fine and secure - something is obviously moving to cause the T-Case to move - What else could it be??
Jalapeño, IISY?
23 May 2011 12:05 #16833
Replied by mlines on topic Re: Clunk/Clang - when in 4Low .
"Frozen" universal joint?
23 May 2011 12:15 #16835
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Clunk/Clang - when in 4Low .
All UJ's look fine Martin - although it may be worth me takin them all off for detailed inspection.
Jalapeño, IISY?
23 May 2011 12:17 - 23 May 2011 12:18 #16836
When I have had one freeze on me the only way to tell was to release the prop and check how freely it moves around. It was stiff in one direction :ohmy:
Last edit: 23 May 2011 12:18 by mlines.
25 May 2011 10:13 #16927
by maverick
Jalapeño, IISY?
i think i've found it ...
All the T-case rubber mounts are NEW and are not rotted, or split.
But, then I remembered there's a rubber mount/bush at the Gearbox end (just below where the short/stubby propshaft is) … the bush on mine is ok, not rotted or split, but there is a main bolt going through it, to secure it … my bolt was loose … it's not loose anymore!!
Martin - I will take all the props off this week, and inspect them - If i need replacements, do you stock them??
Have i fixed it ... Only the next 4x4 trip will tell ... errrr when is that ... Arrrr YES, June 5th - Shropshire!
Jalapeño, IISY?
Time to create page: 0.169 seconds
