Corroded front diff breather pipe
  • Member
17 May 2011 15:21 #16447 by Member
Corroded front diff breather pipe was created by Member
My new mot gives an advisory on corroded front diff breather pipe. I know what they are and what they do and as I don't go wading with my jimny it shouldnt be an issue. Have I got that right or is there something I can do to ward off any further problems? Thank you.
  • srcars
17 May 2011 17:33 #16455 by srcars
Replied by srcars on topic Re: Corroded front diff breather pipe
:unsure: I think I would contact them and confirm that they mean breather pipe.
I wouldnt call it a breather pipe its more of a cap and I cant see how it would relate to an MOT ?
17 May 2011 19:19 #16465 by facade
They probably mean the vacuum pipes for the hubs.
These rust very badly, then snap or leak and stop the hubs working.
I would crawl underneath one day and have a look, likely where they go along the drivers side trailing arm.
The following user(s) said Thank You: Member
17 May 2011 19:36 #16467 by Johnniehec
I agree with Facade, the hub vacuum pipes go all the way along the axle and over the diff, I don't think it would be an MOT item? somebody will know.
John.
  • ooky_123
17 May 2011 21:47 #16469 by ooky_123
Replied by ooky_123 on topic Re: Corroded front diff breather pipe
Def not an MOT item ... mine were disconnected, and my tester said "we reconnected the 2 pipes on your chassis for you ... they looked important .... and are quite rusty" ..
he was suprised when I told him the vac system was disconnected as I have the hubs manually locked :)
they can put advisorys, but it doesnt mean anything...
On my other vehicle, I have a cut down private plate. The plate dimensions still meet the law and legeslation on lettering height and minimum boarder (confirmed by the police) and they still issue advisory's...
  • supergaz
18 May 2011 15:29 #16508 by supergaz
Replied by supergaz on topic Re: Corroded front diff breather pipe
I'm going to remove my vac pipes when I come to paint my axle, I have manual hubs so its just extra tat to get in the way.
