Isolating the engine for an oil change
  • DVs-Jimny
  • Visitor
  • Visitor
20 Apr 2011 08:26 #15268 by DVs-Jimny
Isolating the engine for an oil change was created by DVs-Jimny
How do you guys stop your Jimny firing up once you have carried out an oil change as the filter will be pretty empty until the oils pumped round ?
Thanks
20 Apr 2011 08:36 #15269 by ooky_123
Personally, it doesnt bother me .... I just turn it over a few times and switch it off as soon as it catches. then, after 3 or 4 turns, just fire it up, and leave it idle, occasionally blipping the throttle until the engine is warm, and im putting things away, and tightening up the sump plug / oil filter when warm.
Others may have different ways of doing it, but Ive been changing oils for the last 20 years and it seems to work for me.
Former owner of Little "Ooky", who has now started a new life in Shetland
The following user(s) said Thank You: DVs-Jimny
20 Apr 2011 10:47 #15273 by maverick
I'm with ooky_123 here - but i also 'prime' my new oil filter (thats put some in it - sort of can be messy) ...
Or, just click/stop-engine/clickstop-engine a few times ... then after that just let oil get around engine before you start revving it!!
HTH's
Jalapeño, IISY?
20 Apr 2011 11:05 #15274 by andyw
After draining oil out, sump plug back in, fold passenger mirror in, place 3 cusions on floor, few mates to ease jimny on it's side, old filter off, fill new one and screw new on, get mates to put beer cans down and give you a lift getting it back on four wheels, then put in new oil by this time the oil in new filter has drained out back into engine.
So as others , be gentle:woohoo: matting faces will have a touch of oil on any way, job sorted
Andy
  • doncarlyon
  • Visitor
  • Visitor
20 Apr 2011 15:37 #15281 by doncarlyon
Replied by doncarlyon on topic Re: Isolating the engine for an oil change
Cant you just unplug the coil pack and remove the fuel pump fuse and then turn the engine over?
20 Apr 2011 19:51 #15289 by maverick
I've probably changed oil/filter a hundred+ times ... never ever had a problem - priming the filter was taught me by my father, and his father before that ... BTW, I'm over 50.
Jalapeño, IISY?
Time to create page: 0.198 seconds
