RockLobster - Thankyou Mr RockWatt
- Thank you received: 34
04 Apr 2011 09:44 #14460
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
RockLobster - Thankyou Mr RockWatt was created by ooky_123
Money Well spent, just waiting now for delivery of my new Crawlerbox.
Now Ill beable to use 5th gear again on the roads and upgrade to 31's as soon as I get the thing fitted.
One question, how easy are they to fit ? is it a quick job or more involved ?
I understand im going to need a few additional items to mount it to the Jimny transmission ... Dont suppose anyone has any of these items kicking around spare ?
Jason
Jason
- Little Terror
- Visitor
04 Apr 2011 13:57 #14468
by Little Terror
Replied by Little Terror on topic Re: RockLobster - Thankyou Mr RockWatt
Nice one, ive been looking at these in action on youtube and they look like they completely transform the car, how much did you get it for and what ratio is it.
04 Apr 2011 17:57 #14482
by kirkynut
Replied by kirkynut on topic Re: RockLobster - Thankyou Mr RockWatt
They are quick and simple to change once you have all the right bits. I'm sure Richard has guided you as to what you need, SJ413 front prop and the right flanges and SJ413 mini prop etc.
If flanges are an issue, see Martin's guide.
When you fir the speedo conversion, the sensor needs to be quite close to the gear to be able to pick it up. About 1mm or so I found by just moving it closer and closer until it worked.
I just used a bolt with a few nuts to lock it in the right place along the bolt and the bolt to the sensor and bracket. You'll see what I mean.
Are you getting one of Richard's bucket mounts - if not I would urge you to spend the little extra to get one rather than just have arm mounts as it will protect the transfer box no end. My bucket mount has been bashed and scraped to hell and back and it would have been the transfer box it's self otherwise.
Also, as noisy as they can be as they transmit the transmission noise, do use the nylon bush and bolt mounts that Richard will give you with it. I can't see rubber mounts lasting long.
04 Apr 2011 20:53 - 04 Apr 2011 20:55 #14492
by ooky_123
Replied by ooky_123 on topic Re: RockLobster - Thankyou Mr RockWatt
Cheers for those Gems .. Richard has promissed to write down what I have to do .. Im probably going to have to source the extra bits and give them to a garage as I never have the time to spend installing myself.
Richard has told me, the ratios are 1.5:1 High and 4.16:1 Low.
As for price, I donot want to post specifics on the forum ( I paid a little more because Richard sourced the required boxes ).
Ill wait to see the finished article and then start a shopping list...
Last edit: 04 Apr 2011 20:55 by ooky_123.
05 Apr 2011 18:00 #14544
by kirkynut
No probs, it's only a couple of hours work mate but I know you fly all over the place - literally!
Keep an eye on Suzuki Club Uk's forum, you'll have to join it obviously, but they often have lots of SJ bits for sale.
I would get new UJ's put on the SJ front prop when you do get one, so you know it's good to start with, rather than have to trace vibrations etc. I got the balance on mine checked too as they are all a bit old now.
If you can, get greasable UJ's - ie: with a grase nipple. I asked for them but didn't get them - ahhhhh! Next time Gadget! I'll have a bash at fitting them myself next time I think and source them myself. I don;t think they are as hard as I was frightened they would be.
You will be amazed at the control you gain more than anything.
When you tip it over the top of a large hill you no longer tabogan to the bottom with no engine braking, you plod down against alot of engine braking.
Also, being able to crawl over bumps gently, rather than using momentum all the time to avoid you stalling or running out of puff is great. It's a different way of driving and far more relaxed and as I say - controlled.
05 Apr 2011 18:50 #14554
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: RockLobster - Thankyou Mr RockWatt
Just one more little thing
You also need to bend the gear leaver due to it,s position .... in the samy original position it will be jammed in 4H
I think from what I was told that this is the most difficult part of the lot and they need serious heat to bend ...
Cant wait to get my one fitted as well .....
Time to create page: 0.192 seconds
