Springs
  • Member
28 Mar 2011 08:05 #14168 by Member
Springs was created by Member
will vitara +2 inch springs fit a jimny?
  • panosd
28 Mar 2011 10:26 #14173 by panosd
Replied by panosd on topic Re: Springs
Only the rear springs of vitara fits at jimny.
And you might need a teflon spring spacer at front to correct
the front lean of the car because all 4 springs you are going to fit have the same height.
  • Member
28 Mar 2011 10:34 #14175 by Member
Replied by Member on topic Re: Springs
O right, what's the reason why the fronts dOnt fit? I rake it it's the drivers side front that needs the spacer ?
  • vitara_mad
28 Mar 2011 12:02 #14180 by vitara_mad
Replied by vitara_mad on topic Re: Springs
if vitara rear springs fit what about using some rover 600 rear springs as they are used on the rear of vits to give a 3" lift ????
  • biggaz
28 Mar 2011 15:07 #14186 by biggaz
Replied by biggaz on topic Re: Springs
what about weight difference between vit and jimny? is there much as this may affect the ride!
  • Member
28 Mar 2011 17:33 #14191 by Member
i can see the springs on vitara's being stronger/take more weight, bigger engine, and bigger in size, but as for the rover 600 springs, they may be softer.
so you wreckon the rover 600 springs will fit a jimny and lift by 3"? why wont they fit the front?
Time to create page: 0.094 seconds
