CRAZY DEATH WOBBLE
  • Top Rope Terry
24 Mar 2011 20:31 #13996 by Top Rope Terry
CRAZY DEATH WOBBLE was created by Top Rope Terry
To all with death wobbles! I have had an aggressive death wobble that has slowly got worse over a year now and after lots of money parts and blood me and my 2 step fathers finally found the problem. It turns out there was half an inch play on the forward panhard rod bracket holes (all of them) which did not expose its self with out a bit of side to side force, but after changing the bushes buying some new bolts and welding a bit of steel on over the old holes with a new tight fit 12mm hole for the bolts i now can drive it with zero wobble and no worry of soiling my self. :laugh: :laugh:
good look to anyone who wants to try this hope it helps.
26 Mar 2011 21:00 #14098 by kirkynut
Replied by kirkynut on topic Re: CRAZY DEATH WOBBLE
Well done mate and cheers for sharing your findings!
There are so many things that seem to be able to cause the Wobble of the Death kind it seems that the only way to ensure it does not rear it's ugly head once more is to replace every single component or improve it so as better than new as you have done!
  • Top Rope Terry
30 Mar 2011 14:09 #14289 by Top Rope Terry
Replied by Top Rope Terry on topic Re: CRAZY DEATH WOBBLE
yeah there expensive when you don't know whats wrong thank god i got to bottom of it :laugh:
30 Mar 2011 18:09 #14296 by maverick
Replied by maverick on topic Re: CRAZY DEATH WOBBLE
I'm glad you've found the source of yours ... but the DW is different on almost everyone's Jimny.
I've changed King Pins, Bearings, Pan Hard bushes and Rose Joints, Steering Drag Links ... you name it I've done it ... and still i have a 'slight' DW at 38mph ... and then at 65mph.
I'm happy with that ... as before all those changes it was sheer DW Hell.... at 38mph i could barely hold the steering wheel, and speeds over 60mph were just not possible.
I think, the only thing that is causing me grief now are the tyres have become un-balanced - not surprising as they've done 17,000miles, and have various pieces missing off them!!
Jalapeño, IISY?
  • benji
02 Apr 2011 20:16 #14377 by benji
Replied by benji on topic Re: CRAZY DEATH WOBBLE
noticed 2day ive bent my panhead rod. so 2morrow i think ill take it off and blow touch her back to shape. and my steering is off badly. like half the steering wheel of. would this be because of the wobble and knock it off?
  • Top Rope Terry
03 Apr 2011 14:37 #14416 by Top Rope Terry
hi yeah i think a bent panhard would cause you grief wow that sucks and yeah i've found wheel balancing has played a huge factor with my wobble even more so with the bigger tyres.
Time to create page: 0.130 seconds
