Winch Questions!
- Emplan
23 Mar 2011 21:06 #13914
by Emplan
Winch Questions! was created by Emplan
Hi Guys,
Is there a correct poundage/tonnage of winch that a Jimny should have or is it like asking how long is a piece of string?
Is there a recommended make?
And importantly for me, as i'll be using the little motor as a semi daily drive i'd really like it hidden within the original bumpers, i have had a look at the photos here of the winch in original bumper build guide, is there a way or has anyone seen a less obtrusive way of doing it?
Regards
Emplan
Regards
Emplan
- Brian.SMC
23 Mar 2011 22:20 - 23 Mar 2011 22:20 #13925
by Brian.SMC
Replied by Brian.SMC on topic Re: Winch Questions!
8500lb will do a jimny.
You could make it removable and keep it in the boot until you need it.
Last edit: 23 Mar 2011 22:20 by Brian.SMC.
- Little Terror
23 Mar 2011 22:32 #13927
by Little Terror
Replied by Little Terror on topic Re: Winch Questions!
Yeh 8500 is plenty good enough for a jimny,im not going to bother with one on mine all i used my last one for was landrovers i would sooner leave them stuck lol.:evil: :laugh: :laugh: :laugh:
- a18suf
25 Mar 2011 06:40 #14014
by a18suf
Replied by a18suf on topic Re: Winch Questions!
mine is hidden between bumper and have campion 6500 one. it has been more than enough for me and ive even pulled some bigger cars with it one was a pajero and it did it with ease
25 Mar 2011 08:06 - 26 Mar 2011 20:28 #14024
by kirkynut
Replied by kirkynut on topic Re: Winch Questions!
I've found that most people see 6000Ib as the minimum for a Zuk and most people with a 6000Ib are happy.
I have a 9500Ib Superwinch and it is great. Has pulled me wherever I have wanted, out of gloop and up steep hills without any signs of stopping.
They're about another £100 over a Champion or T max but mine was 2nd hand so only £250 and cost me nothing to clean and rebuild. It's like new inside now.
I would always use synthetic rope though. At the time this limited my choice of winch to the more expensive end as I was told I needed an external drum due to the brake in the drum causing heat transfer to the rope which damaged the rope.
Now some people I respect the opinion of are saying that's rubbish. I would take advice from several winch retailers and see what their collective opinion is.
I would only use rope as I've used wire before lowering a Lifeboat into the water when I was a crew member and in that usage it was horrid to use. Albeit rust was accelerated due to the salt, the odd frayed bits were evil.
Also, I've snapped a rope and regularly see others snap. Wire is no stronger but rather than drop to the floor can flick about and there is enough tension to mame. I've not seen one snap as I've barely seen one used, everyone uses rope here.
Winch solutions do a Marlow plasma for £145 + vat but if you can afford it I think goodwinch upgrade wire to rope with an alley fairlead for just £125 and its bowrope, which is regarded as the best.
It all comes down to money at the end of the day and what you intend to use it for. If its a safeguard on greenlanes a cheap 6000Ib with wire is ideal, for much more I'd go bigger if you can afford it but then get rope.
Just my thoughts and others will disagree, no doubt having used wire without issue for years or something. I wouldn't like to be at a pay and play and seriously injure someone with a snapped cable flying through the air and you can't always see or get through to people to get them to move.
Last edit: 26 Mar 2011 20:28 by kirkynut.
- Emplan
25 Mar 2011 19:21 #14068
by Emplan
Any chance of some photos please :whistle:
And a build guide if thats possible, dont ask for much do I
Replied by Emplan on topic Re: Winch Questions!
a18suf wrote: mine is hidden between bumper and have campion 6500 one. it has been more than enough for me and ive even pulled some bigger cars with it one was a pajero and it did it with ease
Time to create page: 0.105 seconds
