LOOSING ANTIFREEZE/WATER IN JIMBOB-HELP HELP HELP
  • userlw
  • Visitor
  • Visitor
24 Feb 2011 18:20 #12103 by userlw
CAN ANY1 HELP ME PLEASE.HAD JEEP BOUT 8 MONTHS WHE BOUGHT SELLER SAID WATER PUMP BEEN CHNGD-WHE DROVE HOME TEMP WET THRO ROOF-SO WE CHANGED RAD AND TEMP WAS FINE.
BUT IM USING ANTIFREEZE LIKE NO TOMORROW AD CANT FIND A LEAK \?IVE DRAINED RAD RE FILLED AD EVERY 2 WEEKS A FULL RAD IS EMPTY \/\?
I HAD IT PRESSURE TESTED 2 WEEKS AGO-GARAGE SAID PRESSURE PERFECT?
I HAD IT CHEMICALLY TESTED TODAY AND THAT SHOWED NOTHING?
IF IT HAD BEEN HEAD GASK IT SHOULD HAVE SHOWN ON CHEMICAL TEST SHOULDNT IT ?
CA SOMEOE PLEASE PLEASE HELP ME AS I LOVE MY JIMBOB AND SO DO MY KIDDIES-ITS GOT US THRO EVERYTHING!!!!
HELP HELP HELP FELLO JIMBOBS...
25 Feb 2011 06:56 #12147 by kirkynut
It could be the headgasket still. The chemical test I take it was in the coolant. Sometimes it doesn't always show up on those test, I'm not sure why.
Otherwise it could be a leak and it's leaking onto something hot like the inlet manifold and evaporating as soon as it's leaked stopping you from finding it, I've had this before. It could be a leak on the inlet manifold for example.
Some leaks only leak when the engine is cold and as it heats and expands it closes the gap and stops leaking.
Did it start exactly the same time as you changing the rad? It could be a rad hose ever so slightly leaking. Did you use new clips of the Jubilee type or re-use the spring type clips on the rad hoses? You need new ones really and Jubilee Clips of the correct sixe ot they go oval and don't seal.
I would start it from cold and examine everywhere that has water in it from cold all the way up to operating temperature a few times over to try and find a leak.
Otherwise if it got hot for you, how many times did it get hot for the previous owner, especially when the water pump failed, as this could have warped the head leading to headgasket failure and it's just not bad enough yet to show up properly.
If you can't find it, it might be a case of just keep topping it up and using it until you find the cause - either the leak becomes apparent or the head gasket blows completely, whichever is the cause.
You could also try a compression test on each cylinder but if it's running OK I don;t know it would show anything yet. If all are high and even, it might suggest the head gasket is in good order though, as your chemical test is showing at the moment.
I've said alot now and don't know I've helped much but think I might have???
  • goatboy
  • Visitor
  • Visitor
25 Feb 2011 07:22 #12151 by goatboy
have you checked the carpets aren't wet? Could be a leaking heater matrix...
Oh and please turn your CAPS lock off! ;)
25 Feb 2011 09:27 #12159 by mcjimny
My thoughts as above, check for a wet carpet as it could be the heater matrix or if theres no sign of a leak its evaporating inside the engine. Would still investigate the headgasket further, you don't know how long the water pump was a problem before it could have been leaking a while. When you changed the rad it could be coincidental.
My old sj would boil up constantly and did it for nearly a month before the headgasket let go! It turned out the rad had a leak out of sight and was drying before you could find it.
  • userlw
  • Visitor
  • Visitor
26 Feb 2011 06:12 #12190 by userlw
Thanks guys.
I have checked carpets-not any sign of water-i ill get my hubby to check radiator again-but it just seems so odd that i cannot find it-but il have my hubby to look at all ur advice guys and get back to u .
  • jaffaman
  • Visitor
  • Visitor
24 Apr 2011 20:10 #15436 by jaffaman
Hi there,some years ago I use to drive a morris J4 van,Yes I know,a long time ago???? I had a leak no one could find but I did .after working with the man who clean out the drains he showed me what he used to track the pipes under ground, a dye ,he put it in the pipes ,ding'''''dong'''yes you guessed it !!.
I put red dye in to the rad,a fair bit,bit too much realy but the leak left a red sail trail streak back of the water pump,gasket was seeping,got cha....That is what I do now to find leaks on the out side of the
engine,if not it's the head gasket,I hope this helps,works for me,dye off Flee bay..........:woohoo:
Time to create page: 0.140 seconds
