Special Tracks Diff Eaters ????
  • Bannerbrother
15 years 9 months ago #11088 by Bannerbrother
Special Tracks Diff Eaters ???? was created by Bannerbrother
Was wondering if anyone using special tracs on jimnys has found that they seem to be replacing the diffs regualy? my freinds seem to be at the breakers constantly
diahatsu 235x75x15 2 front diffs
defender 90 265x75x16 both front and rear
defender 90 265x75x16 front all these in less than 10 months
i was considering some specal tracks (once i get a jimny that is) because they realy do look the business and perform well even, if they are noisy on the road but dont want all the extra unreliablity.
  • mcjimny
15 years 9 months ago #11094 by mcjimny
Replied by mcjimny on topic Re: Special Tracks Diff Eaters ????
Depends how they are driving i would say, with any tyre if it loses traction and suddenly gains it the shock load through the drive train will result in something giving up, that may be a cv, shaft or your diff. If you were cross axled for example and one wheel was spinning away and you manage to find drive all that energy will be transfered in milliseconds to your drivetrain with potentially expensive consequences.
15 years 9 months ago #11097 by mlines
As just said, probably driving technique. The "Balls out the window, spin the wheels" approach soon breaks things with the shock loading when the wheel suddenly grips. I see this a lot at my local club where the technique to climb hills is based on the mass of the vehicle and Kinetic energy. They approach the hill flat out, climbing it and jumping over the crest. The problem is that when they land the diff explodes. Not only that, but if you fired a solid concrete block at the hill fast enough it would climb to the top so it has little to do with skill and engineering and everything to do with horsepower and brawn. Put a Rocklobster or even lower into a lightweight Jimny with reasonable tyres and let it crawl up the hill using mind and engineering to overcome the obstacle, thats the way to do it!
I have had the Jimny 3 years and as far as I can remember only taken out one CV, this is despite people describing the Jimny set up as being made of chocolate.
  • adamjimny
15 years 9 months ago #11102 by adamjimny
Replied by adamjimny on topic Re: Special Tracks Diff Eaters ????
mlines wrote: As just said, probably driving technique. The "Balls out the window, spin the wheels" approach soon breaks things with the shock loading when the wheel suddenly grips. I see this a lot at my local club where the technique to climb hills is based on the mass of the vehicle and Kinetic energy. They approach the hill flat out, climbing it and jumping over the crest. The problem is that when they land the diff explodes. Not only that, but if you fired a solid concrete block at the hill fast enough it would climb to the top so it has little to do with skill and engineering and everything to do with horsepower and brawn. Put a Rocklobster or even lower into a lightweight Jimny with reasonable tyres and let it crawl up the hill using mind and engineering to overcome the obstacle, thats the way to do it!
could not agree more steady away. few times a little momentum is needed but not much just enough to keep a steady pace. im with you 100% on this martin
  • Bannerbrother
15 years 9 months ago #11120 by Bannerbrother
Replied by Bannerbrother on topic Re: Special Tracks Diff Eaters ????
yeah i had surspected thats what it was, but wasnt sure. another friend of mine has had some on his 90 for over 12 months no problems at all. however he does have to accept defeat a few times more than others as crawling up some of the steep slopes isnt enough, and you do need some momentum. surpose realy it depends on how much you want to thrash your truck.
15 years 9 months ago #11144 by kirkynut
It is as has been said. I have only got Kumho KL71's so never get enough grip to cause issues unless on rock. I know my Mrs can lack mechanical sympathy but even in the Lakes on Rock when she has spun the wheels up when cross axle and suddenly got grip nothing busted.
On mud they won't break anything. But they are not making the most of my Rocklobster. If I had Special Tracks or similar, using momentum would be a thing if the past as I would have grip to crawl up everything and would know not to allow spinning up or I would expect breakages.
If you still can't get up it or across it, don't get all aggressive with it, use that electric thing wrapped in string on the front! If you don't have a winch, get one, it's cheaper than lots of diffs!
Time to create page: 0.096 seconds
