Spring /Body Lifts..?
  • lukeyblunt
04 Feb 2011 16:49 #10942 by lukeyblunt
Spring /Body Lifts..? was created by lukeyblunt
Just a quick, dumb question.
What's the difference between the two..?
and where would be the best palce to start?
Thanks all!
  • biggaz
04 Feb 2011 17:03 - 04 Feb 2011 17:06 #10943 by biggaz
Replied by biggaz on topic Re: Spring /Body Lifts..?
Spring lift, uses longer springs to give the lift say 2 or 3 inch longer than standard, either longer springs or spacers on top of normal springs to give the effect of longer springs
Body lift, uses spacers to lift actual car body off the chassis by however many inch. Basically detach body from chassis, lift and fit the spacer in the gap.
Last edit: 04 Feb 2011 17:06 by biggaz.
  • panosd
04 Feb 2011 17:24 #10946 by panosd
Replied by panosd on topic Re: Spring /Body Lifts..?
Better way is using springs. With this way you avoid getting high your cars weight center.
Its better during off-road. More articulation,better off-road and on road response.
Body lift is usually being used after tuning suspension in order to fit bigger tires.
  • lukeyblunt
05 Feb 2011 19:22 #11043 by lukeyblunt
Replied by lukeyblunt on topic Re: Spring /Body Lifts..?
Super ! Thanks.
So they both similarly increase /improve ground clearance ..?
  • lukeyblunt
05 Feb 2011 19:25 #11045 by lukeyblunt
I ask, because i noticed the flex in the suspension when just one wheel was on slightly higher ground.
Attachment IMG00345-20110204-1548.jpg not found
And i quite liked the outcome !!
  • mkay
06 Feb 2011 12:40 #11090 by mkay
Replied by mkay on topic Re: Spring /Body Lifts..?
is that tyre bald?
Time to create page: 0.172 seconds
