Spring /Body Lifts..?
- lukeyblunt
04 Feb 2011 16:49 #10942
by lukeyblunt
Spring /Body Lifts..? was created by lukeyblunt
Just a quick, dumb question.
What's the difference between the two..?
and where would be the best palce to start?
Thanks all!
Thanks all!
- biggaz
04 Feb 2011 17:03 - 04 Feb 2011 17:06 #10943
by biggaz
Replied by biggaz on topic Re: Spring /Body Lifts..?
Spring lift, uses longer springs to give the lift say 2 or 3 inch longer than standard, either longer springs or spacers on top of normal springs to give the effect of longer springs
Body lift, uses spacers to lift actual car body off the chassis by however many inch. Basically detach body from chassis, lift and fit the spacer in the gap.
Last edit: 04 Feb 2011 17:06 by biggaz.
- panosd
04 Feb 2011 17:24 #10946
by panosd
Replied by panosd on topic Re: Spring /Body Lifts..?
Better way is using springs. With this way you avoid getting high your cars weight center.
Its better during off-road. More articulation,better off-road and on road response.
Body lift is usually being used after tuning suspension in order to fit bigger tires.
- lukeyblunt
05 Feb 2011 19:22 #11043
by lukeyblunt
Replied by lukeyblunt on topic Re: Spring /Body Lifts..?
Super ! Thanks.
So they both similarly increase /improve ground clearance ..?
- lukeyblunt
05 Feb 2011 19:25 #11045
by lukeyblunt
I ask, because i noticed the flex in the suspension when just one wheel was on slightly higher ground.
And i quite liked the outcome !!
Attachment IMG00345-20110204-1548.jpg not found
- mkay
06 Feb 2011 12:40 #11090
by mkay
Replied by mkay on topic Re: Spring /Body Lifts..?
is that tyre bald?
Time to create page: 0.259 seconds
