jimmy winch
- dave t
04 Feb 2011 13:33 - 04 Feb 2011 13:36 #10921
by dave t
jimmy winch was created by dave t
No eBay APP ID and/or Cert ID defined in Kunena configurationwould this be ok to go in a jimmy. off flea bay
Last edit: 04 Feb 2011 13:36 by mlines.
04 Feb 2011 13:40 #10923
Replied by mlines on topic Re: jimmy winch
Its very low powered. Remember that a winch only works at its rated pull on the last layer of the drum, it will be a lot less powerful on the top layer. You can multiply its pull by using a snatch block, a snatch block link will incress its pull to 7000lb on the last layer.
You would not be able to pull stuck Landrovers out but you could recover yourselve from a lightly stuck hazard.
- dave t
04 Feb 2011 13:47 #10925
by dave t
Replied by dave t on topic Re: jimmy winch
Thanks martin i need a bit more grunt then, what size would you recommend please. cheers dave.
- Pete E
04 Feb 2011 14:09 #10927
by Pete E
Replied by Pete E on topic Re: jimmy winch
Would echo what Martin says...How much power you need depends on what you intend using it for...If you doing serious off roading and comps ect, you'll be better off getting a good quality winch of about 8000lb or more...
For more mundane once-in-a-while use, I'd say something like 6500lb would be ideal...I suppose you could go lower, but thats what I do look at...
Regards,
Peter
Regards,
Peter
- dave t
04 Feb 2011 15:20 #10934
by dave t
thanks guys, its only to pull me and my mate out when i get stuck lol, so 6500lb it is then.
- biggaz
04 Feb 2011 15:27 #10935
by biggaz
Replied by biggaz on topic Re: jimmy winch
yeh a few people have mentioned this and 6500 comes in at most people minimum..
pretty sure this would be good enough but more money of course
cgi.ebay.co.uk/Champion-C8000S-12v-Winch...&hash=item43a3618292
or these are cheaper, but probably "cheaper"
cgi.ebay.co.uk/HEAVY-DUTY-8000Lbs-12v-RE...&hash=item2a0d2fafdd
ive noticed the motor power on the cheaper ones are way lower!
like 4.2hp on the champion vs 1.8hp on the longhorn or whatever.
Time to create page: 0.246 seconds
