Rock Lobster Box On Ebay
  • Gary Whenmouth
03 Feb 2011 19:59 #10894 by Gary Whenmouth
  • adamjimny
04 Feb 2011 06:47 #10905 by adamjimny
Replied by adamjimny on topic Re: Rock Lobster Box On Ebay
awfully tempted just not sure price wise i was thinking 200 max?
04 Feb 2011 07:23 #10908 by mlines
Replied by mlines on topic Re: Rock Lobster Box On Ebay
I would ask the seller how he joined the gears together. Don't get me wrong, he could have access to the right equipment and skills and it could be a good job, however some people in the past have thought they could just weld everything together with inevitable results.
Ask him how it was done and see if he answers with a nice technical explanantion, run away if he just says he "cut them and welded them , mate"
  • biggaz
04 Feb 2011 12:50 - 04 Feb 2011 12:52 #10918 by biggaz
Replied by biggaz on topic Re: Rock Lobster Box On Ebay
he says he machined the gears himself so id hope hes pretty technical! :ohmy:
Am i right in thinking thats not as a Rockwatt one as in the on road 2wd ratios are just normal so the 4low is the modified part?
I mean, would this not help your larger tyres on road like a rockwatt one would, sorry if im way off :lol:
Last edit: 04 Feb 2011 12:52 by biggaz.
04 Feb 2011 13:04 #10919 by mlines
The answer to that depends on where you started from!
First of all the advert is aimed at SJ owners not Jimny owners so he is referring to people who either have an SJ413 or SJ410 as a starting point.
A Rocklobster has an SJ410 High Ratio and a Modified Low Ratio.
Therefore if you have an SJ410 then this conversion does not affect High Ratio and gives you a nice low Ratio.
An SJ413 normally has a higher High Ratio than an SJ410. Therefore fitting a Rocklobster to an SJ413 lowers BOTH the High and Low Ratios. It drops the High Ratio from SJ413 standard to SJ410 Standard and provides the nice low ratio.
The Ebayer should know this if he is technical so it might be worth asking him this as a "tester"
For us Jimny owners it provides a lowered High and a lowered Low Ratio.
  • biggaz
04 Feb 2011 13:40 #10922 by biggaz
Ok, thanks for that!
if i hadnt of just bought a welder ............
Time to create page: 0.354 seconds
