Rear wheel bearings
  • colin
07 Aug 2009 23:15 #1087 by colin
Rear wheel bearings was created by colin
Much appreciated the info on replacing rear wheel bearings nice1 :cheer: does anyone know how often I should expect to do this job using the car for only road travel and no heroics roughly 6000 miles per year
thanks for any reply
08 Aug 2009 11:08 #1090 by kirkynut
Replied by kirkynut on topic Re:Rear wheel bearings
They should last for a long time if you are only really using it on the road. How many miles had the old ones done out of interest?
The things that shorten their lives are the constant use through muddy or sandy environments as it gets into the bearing somehow and offset wheels or wheel spacers increase the leverage on the bearings but in my mind on the road this shouldn't decrease their life by much.
Off road use puts strain on them at harsher angles, not helped with the extra leverage by offset wheels / spacers.
  • colin
08 Aug 2009 13:34 #1092 by colin
Replied by colin on topic Re:Rear wheel bearings
had a garage replace one(driver side rear) shortly after I got the car 3 years ago from a dealership (no info about previous owner) both rear wheels have always worn tyre tread on the inner side of rim, I am now replacing the oil seal on the passenger side as it is now leaking, so I thought it would be a good Idea to replace the wheel bearing as I have to take the half shaft out anyway and hopefully fix tyre wear problem,the bearing has a bit of play on it should it have any at all? the car is a W reg (2000 i think) thanks for reply.
  • colin
08 Aug 2009 19:30 #1094 by colin
tip for future, the spring clip on the handbrake cable is easier to get at once the four bolts on the axle have been removed :cheer: expect each side to strip down at a leisurely tea and biscuits pace of 2 hours each once you have it up on the axle stands
  • Jamie
09 Aug 2009 17:56 #1098 by Jamie
Replied by Jamie on topic Re:Rear wheel bearings
I've had my Jimny a little over 18 month's now and bought
it brand shiny new with 1.3 miles on the clock and i did my first
rear bearing at 9000 miles but mine is regulary off road
  • colin
09 Aug 2009 18:24 #1099 by colin
as I have not ordered the new parts yet. does the bearing kit come with the perforated oil distributor that sits behind the oil seal
Time to create page: 0.465 seconds
