Jimny with Toyota axles
14 Jun 2024 12:19 #256281
by safari
if u worry u die if u dont worry u still die so why worry
Jimny with Toyota axles was created by safari
Am thinking of changing the Jimmy axles with Toyota axles any suggestions pro and cons every help appreciated
- Roger Fairclough
- Thank you received: 225
14 Jun 2024 20:00 #256283
by Roger Fairclough
Replied by Roger Fairclough on topic Jimny with Toyota axles
Sources of axles.
Any 70 series but availability not good. All very strong for Jimny but much heavier and wider. Did come with coil spring suspension plus sometimes LSD or electrically powered rear diff. lock.
Earlier Hi-Lux had leaf sprung axles front and rear with same guts as 70 series but probably no rear diff lock and probably no LSD. Probably better availability. Heavier and wider then Jimny.
It has been done before so you are not in the dark!
Roger
Roger
The following user(s) said Thank You: Filipao
15 Jun 2024 05:09 #256285
by safari
Replied by safari on topic Jimny with Toyota axles
I am more concerned about what it involves and ratios being wider is not that much of a problem for me
15 Jun 2024 16:40 #256293
by Manxman
Replied by Manxman on topic Jimny with Toyota axles
Time to create page: 0.481 seconds
