Front LSD or Air Locker?
02 Jun 2022 17:44 #243556
Replied by mlines on topic Re:Front LSD or Air Locker?
Yes, sorry. If you posted whilst the databases were moved then your posts are on the old server
Sent from my moto g42 using Tapatalk
04 Jun 2022 15:17 #243564
by Obarno
Replied by Obarno on topic Re:Front LSD or Air Locker?
I’ve had arb air lockers back and front in my Jimny for the last 10 years and wouldn’t be without them. It means you can drive very carefully over rocky lumpy parts without using momentum to keep,movinng. They flick in and out very quickly so really not a problem. On difficult bits I tend lo leave the rear locker in and when necessary disconnect the front. The locked rear doesn’t stop you steering as generally I’m driving on a loose surface, hence the need for the locker. With arbs you only have to back off a bit, flick the switch and it’s out. Definitely the way to go, but they’re not cheap!
Time to create page: 0.217 seconds
