Jimny-Fox build
- Paul_sterling
13 Oct 2016 20:28 #173516
by Paul_sterling
the very one Keith. not looking for vast HP, the 100hp cal will be more than enough, its the bottom end torque of the 1.0Ecoboost thats the real plus, it has over double the torque of the Jimny engine, its also a very smooth and free revving engine.
Paul.
Replied by Paul_sterling on topic Jimny-Fox build
Keithy wrote: Ahhh 3cyl petrol.....turbo?
Paul.
16 Oct 2016 05:54 #173593
by kirkynut
Replied by kirkynut on topic Jimny-Fox build
You need to think how you are going to get the props to work from the gearbox to the transfer box too. I'm thinking that the Type 9 is much longer than the Jimny box so may bump into the transfer box.
- Paul_sterling
16 Oct 2016 08:38 #173598
by Paul_sterling
thanks Kirkynut,
should be able to measure before commiting to any metal cutting. After that a custom made and balanced prop with the correct flanges on each end should make connection straghtforward.
cheers
Paul.
kirkynut wrote: You need to think how you are going to get the props to work from the gearbox to the transfer box too. I'm thinking that the Type 9 is much longer than the Jimny box so may bump into the transfer box.
thanks Kirkynut,
cheers
Paul.
- jamie_300
16 Oct 2016 08:56 - 16 Oct 2016 08:58 #173600
by jamie_300
Replied by jamie_300 on topic Jimny-Fox build
Since working at Citroen I was really impressed with their Puretech 1.2 engine in all its forms: 82 n/a 110 &130 turbo. Since having a Jimny I thought a three cylinder engine would be perfect for one, but that is far as I got: thinking what a good idea it would be. Three cylinder is definitely the future, I quite the "rough" exhaust note as well!
Last edit: 16 Oct 2016 08:58 by jamie_300.
Time to create page: 0.142 seconds
