let the build commence
- jewi
05 Nov 2015 19:48 #155479
by jewi
let the build commence was created by jewi
Well Christmas has come early for Kieran and Jimny as i have just bit the bullet and bought him a 2"/ 50mm Pro Comp Lift Kit with Procomp ES3000 shocks with dark blue boots. A set of rear shock repositioners/spacers with longer bolts and a Brake Balance Correction Bracket from Jimnybits.
i'm looking forward to getting them fitted but do i need any specialist tools or just what you would find in a normal tool box?
Is there any thing else I will need?
Any help is appreciated.
Paul
Paul
05 Nov 2015 22:41 #155508
Replied by Daniel30 on topic let the build commence
Sounds good look forward to some photos of your progress, you might need some camber corrected bushes
- jewi
06 Nov 2015 22:31 #155611
by jewi
i looked at those but thought it wasn't a necessity or am i wrong?
Replied by jewi on topic let the build commence
Daniel30 wrote: Sounds good look forward to some photos of your progress, you might need some camber corrected bushes
06 Nov 2015 22:35 #155612
Replied by mlines on topic let the build commence
For a 2" lift castor correction bushes are generally not required as the change is tolerable.
The following user(s) said Thank You: jewi
- jewi
14 Nov 2015 21:26 - 20 Nov 2015 16:54 #156282
by jewi
Last edit: 20 Nov 2015 16:54 by jewi.
- jewi
14 Nov 2015 21:30 - 20 Nov 2015 16:54 #156283
by jewi
Time to create page: 0.319 seconds
