My Zuki, James
  • Lozi
21 May 2015 19:36 - 21 May 2015 19:57 #144588 by Lozi
My Zuki, James was created by Lozi
I bought this jimny to get back into laning and didn't intend to do much to it, long story short that idea has gone out of the window as usual so I thought I would start a project thread.
Typically with past car projects I buy all the bits I need then get bored, the car gets sold followed by all the parts. I still have a lot of the parts from my vento vr6 project I got bored of last year lol
I call my jimny James as it's like jim but sounds posher which amused me for some reason lol
I will start by copying my posts from the my jimny section then start on what's been happening after that.
After selling my pajero a few years back in the spur of the moment to buy a mk2 fiesta I saw (that's how I work) I have spent the last few years wishing I still had a 4x4, I have owned a few cars since then but have always been tempted to get another off-roader and since buying a brand new Fiesta ST last year I sold my van to replace it with something more fun.
I looked at pajeros, fourtraks, patrols, 90's, land cruisers etc as I like big diesel 4x4's but somehow after many months of searching and indecisiveness have ended up with this lol
2000 Suzuki Jimny JLX with the earlier (crapper apparently) 1.3 16v SOHC engine
Here are the only pics I currently have of it with the awesome hubcaps still fitted
The first day I had it I decided to go to a local lane to see if the 4wd was working, long story short it wasn't so I got stuck lol
First little bit of mud on it lol
Then the next day I woke up to this
Which was due to the valve leaking so it most probably took a knock off-roading, luckily the spare has a locking wheel nut which I don't have a key for so my first few days of jimny ownership have looked like this
Here's a few pics of my jimny laning in Leicestershire today with my hand winch getting us out of trouble it worked a treat.
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
Here's an update on my jimny
I fitted a square front plate and debadged grill today which I think makes it look a lot better.
Unfortunately removing the old plate left these ugly brackets so I got the grinder out and removed them
[IMG
So now the front looks like this
[IMG
I'm debating getting a couple LED spot lamps or a small LED bar to mount on the A bar but I can't decide.
I also removed the side steps and it now has AVM manual hubs
[IMG
I have also collected a few bits which should really transform it when I actually get round to getting it all fitted.
215/80/15 Black Star Guyane tyres
[IMG
[IMG
2" lift springs from vitmods
[IMG
+2 Pro Comp ES1000 shocks
[IMG
2" body lift from jimnybits
[IMG
Steering spacers and extended brake hose from jimnybits
[IMG
HD rear recovery points from jimnybits
[IMG
There are a couple more things still to arrive before I can get on with it but it's going to be a vast improvement
At this point I had spent a lot more than I intended to but it didn't stop there
Last edit: 21 May 2015 19:57 by Lozi.
  • Lozi
21 May 2015 19:53 - 21 May 2015 19:55 #144590 by Lozi
Replied by Lozi on topic My Zuki, James
Now for more bits I have been buying for it
I sent back the vitmods springs and ordered these 2" springs from jimnybits
[IMG
After much searching around for steels as jimnybits were out of stock of what I wanted I got a message from Russ saying he had some coming back and did I want them so I jumped straight on them, 15x8 black -30 offset.
He said that they were from different batches so the 2 pairs looked a little different but that didn't bother me, on inspection after I received them it would appear that the centres are just welded in the other way round on 2 which I think will give it a bit of a staggered look to them even though they measure up the same offset wise.
[IMG
[IMG
Rock lobster transfer box and fitting kit from Rockwatt
[IMG
I went and collected the transfer box and he is a very helpful knowledgable guy.
I took the cradle unblasted so I could do my thing with it
[IMG
So I grit blasted it
[IMG
Then Keyphos coated it followed by a couple coats of Xylan 1088 on top
[IMG
Bitsforvits had an offer on their last remaining safari snorkel, I couldn't resist so I got it ordered
[IMG
I will be fitting my (very rare) rainbow cloth cossie recaros in it, I have had these many years and fitted them to a few of my previous cars
[IMG
And that's where I'm at with a huge pile of bits none of which fitted, I need to make sure I actually see this one through so I plan to try and get most if it fitted this weekend. Unfortunately the SJ props I bought off somebody on Sunday only got posted out yesterday which means I won't be able to fit the rock lobster which is pretty annoying!
Last edit: 21 May 2015 19:55 by Lozi.
  • Daniel30
21 May 2015 20:09 #144594 by Daniel30
Replied by Daniel30 on topic My Zuki, James
How wierd is that I've had my modulars a while now and when I ordered them from jimnybits I got the same as you but no one mentioned they had sent me different batches anyway the bloke that fitted them put what looks like the deeper offset on the back and the others on the front and it looks good!! :woohoo:
You have a whole load if nice stuff and the seats well they are nice with a capital N!!! :whistle:
  • Lozi
21 May 2015 20:15 #144596 by Lozi
Daniel30 wrote: How wierd is that I've had my modulars a while now and when I ordered them from jimnybits I got the same as you but no one mentioned they had sent me different batches anyway the bloke that fitted them put what looks like the deeper offset on the back and the others on the front and it looks good!! :woohoo:
Brilliant! I actually think the ones that are backwards look a lot better it's wierd how much deeper they look but they are in fact not deeper at all!
They are nice seats but after being in my pajero then my van they are abit worse for wear now
  • Daniel30
21 May 2015 20:37 #144599 by Daniel30
Yeah I kept looking down the side of the jimny to check :lol:
They look good / old school, how about a referb or is that expensive?
  • Lozi
21 May 2015 20:44 #144604 by Lozi
Daniel30 wrote: Yeah I kept looking down the side of the jimny to check :lol:
There's no chance I will be able to find the material to re cover them apparently less than 50 sapphire cosworths left the factory with these seats my old cossie had leather, I cut up the back seat when we took them out of the car they came with so I have a little fabric but not enough.
Time to create page: 0.294 seconds
