Upgrading axles
  • Jimny J
21 Apr 2015 23:03 #142928 by Jimny J
Replied by Jimny J on topic Upgrading axles
From what ive read, I think the cheapest and simplest upgrade would be sj axles with either 1in spacers or different offset wheels. Just grind off old leaf seats and weld on the jimny tabs. Cant remember if you need sj props tho. Been told by a few fellow sj and jim owners that their standard sj axles will happily run up too 35s too.
  • TomDK
22 Apr 2015 05:27 #142931 by TomDK
Replied by TomDK on topic Upgrading axles
Don't believe everything you hear. SJ axles are about the same strength as Jimny. Perhaps slightly stronger CVs but nothing serious.
If you want 35" tyres on a Jimny, you need HD axle internals. Unless of course it's just for the looks.
  • Smoggy
22 Apr 2015 16:50 #142963 by Smoggy
Replied by Smoggy on topic Upgrading axles
Selling my axles if your interested. Want £1400 for both. ☺
22 Apr 2015 20:38 #142978 by kirkynut
Replied by kirkynut on topic Upgrading axles
I think there's a few advantages to Samurai axles.
You can get uprated internals for both axles a great deal easier and they are proven parts.
The front axle swivel seal is actually a seal and not an excuse for one!
Front wheel bearings don't require a press to change.
In fact if I could but a Sammy today with a carb that worked at all angles, proper inertia rear seat belts and a hard top with no rust, I would in a heart beat.
It would get lifted on Llama 4x4 Potty Lift Springs under the axle with a Rocklobster and the axles would be all singing and dancing with discs all round and an X Brake hand brake, super strong shafts and cv's.
  • TomDK
22 Apr 2015 21:15 #142979 by TomDK
kirkynut wrote: I think there's a few advantages to Samurai axles.
I did consider Samurai axles once, because as you say. Uprated internals are proven and cheaper than for the Jimny. But once you've gotten hands on a set of axles and cut and welded new brackets to fit the Jimny, and bought HD internals, the total cost is more than a set of RCV/ RS MFG HD shafts and CVs will be for the Jimny. And the RCV ones are a straight swap.
And why are the HD shafts and CVs for the Samurai easier to get than for the Jimny? You still need to import either from the US or from Italy.
As for the bearings. You do not need a press to change the bearings on a Jimny.
On top of it all, you need 5 cm wheel spacers for the Sammy axles as it's 5 cm's narrower than the Jimny axles.
23 Apr 2015 17:29 #143024 by kirkynut
So that's 25mm each side then Tom? No great issue. You can get wheels with a different offset of spacers or both.
Wheel bearings are easier to change even if you use your oven.
Sammy bits are cheaper as the manufacturers have probably made their R&D back after all these years so are not charging for it any more and the tooling has been about to manufacture them for much longer. New products need their tooling and R&D paying for if a profit is to be made on them.
The welding is an issue if you don't have someone you can trust to do a good safe job of attaching the brackets in the right place so they don't fall off and so they are equal with the right castor angles etc. I am lucky as I have a good friend who is a good fabricator.
To be honest though. I would not spend any more money on my Jimny other than maintenance as A) My interest has been waning for some time and B) My needs would be for a bigger vehicle if I were to spend money on an offroader / greenlaner now.
