Suspension and Wheel Set Up
02 Mar 2014 00:21 #106771 by robs5230
if you can afford them bfg km2 in 215 75 15 are the muts nuts and will do you just fine and go on standard rims . i run 195's which are similar in height just a little narrower and i run insa turbo tyres .there are a few options of lift kits out there and it's really down to your budget. the tyres will give you ground clearance and the lift articulation. if its the odd bit of laning i'd get the tyres first and the lift secondary.
i have said on many occasion, if i hadn't bought mine lifted i would have just put 195's or 215's on it and left the suspension standard. any lift puts strain on the drivetrain
standard jimny - for now
  • TomDK
02 Mar 2014 00:31 #106772 by TomDK
Replied by TomDK on topic Suspension and Wheel Set Up
robs5230 wrote: any lift puts strain on the drivetrain
Please explain.
  • Jimny08
03 Mar 2014 16:54 #106978 by Jimny08
Replied by Jimny08 on topic Suspension and Wheel Set Up
Hi sorry if I'm going over old ground but will 215/75/15 fit my standard 2008 jimny I've read that there are issues with these on the bumpers?
03 Mar 2014 17:15 - 03 Mar 2014 17:17 #106979 by robs5230
Please explain.
really ?? are you trying to test my knowledge to see if i may trip myself up ? if my post is incorrect it would be more beneficial to the original poster that you give the correct information / correct me.
in my opinion, bigger tyres will follow lift. bigger tyres = more stress on the gearing.
axles and gearbox / transmission will not be in the position they were designed to be in.
if caster correction is not applied, the axles will not be sat correctly. axle to radius arms mounts take a beating.
i'm talking about suspension not body lifts by the way
Last edit: 03 Mar 2014 17:17 by robs5230.
  • TomDK
03 Mar 2014 19:16 #107009 by TomDK
robs5230 wrote:
Please explain.
I very much agree with you. Only your comment about any lift puts strain on the drivetrain that puzzled me.
Though I must say, fitting 215's on a 2" lift only adds very little strain, if any.
But 31" tyres fitted does put some strain on the CVs and shafts :)
03 Mar 2014 19:26 #107014 by robs5230
TomDK wrote:
robs5230 wrote:
Please explain.
ok mate, sorry for biting.
Time to create page: 0.156 seconds
