Also making a bull bar - tubular
  • TomDK
25 Sep 2013 01:48 #84287 by TomDK
Replied by TomDK on topic Also making a bull bar - tubular
nzJim wrote: A good idea and I could but it would compromise it's integrity too much, in my opinion.
Agreed.
I wouldn't Loose the box section either.
If you want to cut it out. Replace it with something else.
  • polaarbear
25 Sep 2013 04:22 #84289 by polaarbear
Replied by polaarbear on topic Also making a bull bar - tubular
Hi nzJim,
I managed to fit the winch in sitting above the chassis rails but that's with a 2" body lift so it didn't hit the body cross member.. Could be an idea..
BTW I'm in NZ as well so you're not alone! haha.
Where abouts in NZ are you? I'm in Auckland.
Josh
  • nzJim
25 Sep 2013 05:06 #84291 by nzJim
Replied by nzJim on topic Also making a bull bar - tubular
g'day Josh, good to hear of another nz jimny! I'm down in chch so not likely to bump into you.
I hadn't thought about doing a body lift... hmm... I'll research that. I'd rather not open up another work front though! My tyres fit fine so I don't quite see the point, it's tall enough as it is.
I can get it sitting a fair way back so it's not the end of the world.
Any other pics of homemade bar work?
  • Dorfl
25 Sep 2013 10:46 #84330 by Dorfl
Replied by Dorfl on topic Also making a bull bar - tubular
Will try to get some pics this weekend. Car has 2" body lift and winch is mounted above the rails. If you can avoid it, I would steer away from a body lift (it raises the center of gravity) :( If you need more clearance, employ an angle grinder and hammer :laugh:
Time to create page: 0.377 seconds
