outback jimny
- steffan
08 Aug 2013 05:46 #79325
by steffan
Replied by steffan on topic outback jimny
I believe most people just do an engine conversion as its far more cost effective and you arnt taking the tiny little 1.3 to its limits
- ozjoel
08 Aug 2013 07:22 #79329
by ozjoel
Replied by ozjoel on topic outback jimny
yeah that sounds like the easiest best outcome, see how i go, i have drivin slower, so its not to bad yet lol
- ZookFastback
08 Aug 2013 07:33 #79330
by ZookFastback
Replied by ZookFastback on topic outback jimny
Most people in Oz go for the Suzuki Baleno engine conversion, which gives you a 1600 dohc engine that is a happy revver and about 20 more horsepower. Fairly straightforward conversion been done and pictorialised quite a bit. Can be done in a day.
- Shep
08 Aug 2013 07:50 #79331
by Shep
Replied by Shep on topic outback jimny
Baleno conversion is only an option for a early jimny with a G series motor. I think the pick for a vvt jimny is the 1.6 M series motor from a swift sport. 100kw and 160nm.
- ozjoel
08 Aug 2013 09:03 #79334
by ozjoel
true that, in australia you cant go backwards in an engine conversion, ie. you canbt put an engine in from an older series, and as im in the m13 i would need a similar engine (m15/15/18)
its to do with safety and emissions etc.
what is actually different from a m13 to a m16?
is it just the crank giving it a longer stroke? or are they different bore, crank and block?
what puts me off is the multitude of ecu faults the swap throw up as the m16 and m13 are from different vehicles/different computers.
i was looking at getting the cylinders bored out and cam work for a bit more power, and get the head ported and poillished, undecided, like i said im not really noticing the lack of power to much, i really like the fuel economy.
13 Aug 2013 19:58 #79797
by Rhinoman
You have to use the 1.3 ECU and all its sensors with the 1.6 injectors. Its possible to remap the 1.3 ECU but most people report that it works OK without any mods.
Replied by Rhinoman on topic outback jimny
ozjoel wrote: what puts me off is the multitude of ecu faults the swap throw up as the m16 and m13 are from different vehicles/different computers.
