2" suspension lift
- jfkenpoman
15 Jan 2013 15:12 #58153
by jfkenpoman
2" suspension lift was created by jfkenpoman
which would you recommend, i'll be mainly greenlaning and using jimny for shooting from?
prices and suppliers, how difficult is it to fit?
:sick:
:sick:
- mudman
15 Jan 2013 15:23 #58156
by mudman
Replied by mudman on topic 2" suspension lift
for light green laning and shooting id go with this kit from bits4vits
www.bits4vits.co.uk/store/jimny/1-5-jimn...-black/prod_843.html
this way you have the standard soft and supple jimny suspension and as for fitting its one of the easiest thing to do on a jimny
15 Jan 2013 18:51 #58173
by pgatensuk
2005 Jimny VVT soft top
2002 Jimny Soft top - Sold
2007 Triumph Tiger 1050 - Sold
2011 Kawasaki W800
2002 Twin boys
2001 Kerry Blue Terrier - RIP
2012 GoldenDoodle
Replied by pgatensuk on topic 2" suspension lift
If you can afford it, I would go for the Trialmaster 2" comfort kit. IMO this will gives the best ride quality (better than standard) and good on road handling.
If you are on a tight budget then the Bits4vits spacer kit is a popular option. It gives a slightly harder ride than standard.
Fitting is not too bad only a few bolts on the shock absorbers to undo. Good trolley jack and axle stands required. If you look you find a detailed fitting procedure by dirtydogz. The lower rear shock mounts can be tricky. Fit bottom bolt first before attaching at the top, otherwise you might cross thread the thread on the axle. You can buy rear shock relocation brackets (part of the bits4vits spacer kit) which also over come this issue.
I am well pleased with my Trialmaster kit, completely transformed the ride and performance.
Don't forget that if you go to 2" you should also consider fitting the castor correction bushes. I have yet to do mine. Steering is a little vague but you can live with it.
I did a review a while back on my 2" lift. I will be updating it soon.
Cheers
Paul
Cheers
Paul
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
15 Jan 2013 19:01 #58175
by pgatensuk
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
Here you go jfkenpoman. I'll save you the trouble of looking them up.
About £150 for the bits4vits spacer kit and about £600 for the Trailmaster kit. Various other kits are also available. Another popular kit is available from Jimnybits kit at about £350
Jimnybits 2" kit
Dirtydogz guide to fitting a suspension lift
and my recent review of the trialmaster 2" kit
2" Trialmaster review
IMO go for one of the kits with replacement shox and springs rather than the spacer kit if you can.
Have fun!
Paul
Jimnybits 2" kit
Have fun!
Paul
2011 Kawasaki W800
2002 Twin boys
2012 GoldenDoodle
- jfkenpoman
15 Jan 2013 19:03 #58176
by jfkenpoman
Replied by jfkenpoman on topic 2" suspension lift
cheers mate i have just seen the price of the kit and bushes and ouch haha may have to wait a bit
- jfkenpoman
15 Jan 2013 19:14 - 15 Jan 2013 19:16 #58181
by jfkenpoman
ta paul have been looking lol the 2" lift kit + correction bushes works out at 440 ish :blink:
Last edit: 15 Jan 2013 19:16 by jfkenpoman.
Time to create page: 0.224 seconds
