mercedes G wagon axles on jimny
  • panosd
28 Jun 2012 13:29 - 28 Jun 2012 13:30 #43069 by panosd
mercedes G wagon axles on jimny was created by panosd
I just got a set of GD240 axles with 5.29 axle gear, the rear one with original diff-lock.
I have already turnd the front one in order to work like suzuki axles.
I start thinking of fitting them on my jimny with 235/85/16 and 4.16 t-case( already installed).
My target is to build an everyday plus long distance and greenlaning car.
But i need some help. With 32'' does anyone knows to tell me how much rpm and km/h i will have with
5th gear on? I want to get 100km/h and 4000rpm.
The engine for now will be stock 1300 and in future will be replaced by a M16A.
Last edit: 28 Jun 2012 13:30 by panosd.
28 Jun 2012 13:44 #43071 by Obarno
This will give you hours of fun working out the ratio you want!
www.planet4x4.net/forums/calculator.php
  • mostafa
28 Jun 2012 17:14 #43082 by mostafa
Replied by mostafa on topic Re: mercedes G wagon axles on jimny
panosd wrote: I just got a set of GD240 axles with 5.29 axle gear, the rear one with original diff-lock.
regrding the M13 instead of the stock one..... will it match with the gearbox or any extras needed?
  • panosd
28 Jun 2012 18:56 #43091 by panosd
Replied by panosd on topic Re: mercedes G wagon axles on jimny
I already have a rocklobster, so the only thing i will do is to connect the axles with it using the sami prop
shafts also already installed.
The m13 is my stock engine.
Time to create page: 0.380 seconds
