TIG Welders - Converted Stick any good or waste of time?
- Thank you received: 553
26 Aug 2020 09:49 #227357
by Scimike
TIG Welders - Converted Stick any good or waste of time? was created by Scimike
Any professional welders or keen hobbyist out there?
I fall into the keen hobbyist category and have a fairly decent MIG welder and a cheap DC inverter stick welder that is surprisingly good. I have always wanted a go a TIG welding but don’t want to invest too much.
I have seen youtube videos of people using a DC stick welder converted to scratch start TIG. I appreciate you won’t have hands free control for Amps / starting, but it does appear to be a cheap way to achieve TIG with kit I already have (Gas and torch aside).
Is this actually a viable proposition or should I just save my cash and go for a dedicated TIG welder?
Some cheap TIGs on the market appear to be DC Stick welders, so I am confused as why they are different.
Any feedback on this appreciated to help me decide.
Thanks
Mike
Thanks
Mike
26 Aug 2020 10:26 #227358
by sniper
Replied by sniper on topic TIG Welders - Converted Stick any good or waste of time?
I was a multi coded, multi process welder and the simple answer is yes, you can use the stick set as a power source for DC TIG scratch or lift start.
Cheap Chinese inverters have been a waste of money in the past but things may have changed. I have been out of the game nearly 10 years...
I have seen used commercial sets from Lincoln and Kempi from as little as £500. Thats where I would go, rather than buy a cheap new set.
Once you become proficient at TIG you won't want to use other processes....
Get a gas lens rather than a standard diffuser, much better gas cover....
sniper
sniper
The following user(s) said Thank You: Scimike
26 Aug 2020 21:30 #227388
by Busta
Replied by Busta on topic TIG Welders - Converted Stick any good or waste of time?
I've been an agricultural/hobby welder for many years and recently started doing TIG. I went for a UK made TecArc TIG186i which was around £500 with everything needed to get started (apart from the gas). It's basic by TIG standards but still has high frequency start, remote control either on the torch or a pedal, pulse settings, post flow, slope down etc. All useful features that you won't get on a converted stick unit.
Having done Arc and MIG for many years, and with a days professional TIG training, the learning curve was steep! I haven't tried scratch or lift start but I can only imagine it would make it much harder. HF start makes arcing up easy but it still takes time to get to grips with having a steady hand, maintaining good torch height, not dipping the tungsten etc. With the added complication of a scratch start I'm sure I would have spent even more time sharpening tungsten than I already have!
27 Aug 2020 14:44 #227398
by Scimike
Replied by Scimike on topic TIG Welders - Converted Stick any good or waste of time?
Thanks for the feedback chaps, very interesting and helpful.
Did not know what a gas lens was, Google sorted that, looks like a good device to have. Secondhand is an option, but it's always difficult to get one in your back yard, mainly to see it working.
TecArc don't look a bad unit and a reasonable price, certainly within my price range.
Looks like I need to save a bit of cash and just get the unit I want, be it new or secondhand - mind made up.
Don't fancy making it difficult for myself. I have also determined that without proper control it's not going to be suitable for thinner metal gauges.
So even if I did get it to work I would want a " proper unit " soon after to achieve the welds I want.
Thanks again.
Mike
Thanks again.
Mike
27 Aug 2020 16:49 #227404
by Busta
TecArc also do a multi process MIG/TIG/stick machine that is well specced and not over priced. It has all the features of my TIG model and all the features of a regular MIG, so not as compromised as some machines that claim to do it all. You could replace 2 machines with 1 and gain some more functionality!
