Octane rating behind fancy fantasy names.
02 Jul 2020 08:31 #224381 by HUN
Hi all,
In the continental Europe, the octane rating is clearly marked on the pump with the actual octane number (95, 98).
I'm struggling to find clear information on-line and at the petrol stations about which petrol is equivalent with unleaded 98 petrol in the UK.
I have half a tank of 6 months old petrol in my Jimny and another 10l in cans which is 10+ months old...not good for my Jimny or my Stihl saw either.
Which Shell and BP fuel is true alternative of 98 octane unleaded?
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
02 Jul 2020 10:24 #224385 by 300bhpton
You have to watch octane ratings. There are lots of different grading systems; MON/PON/RON/AKI
I'm pretty sure most of the EU uses RON same as the UK.
02 Jul 2020 10:46 #224388 by Scimike
I am sure I have seen it marked on the last pump I used in the UK, I put some 99 in rather than the other 95 just for a laugh, so I must have been looking at something. Is it just a case of 98 or higher?
02 Jul 2020 14:34 - 02 Jul 2020 14:35 #224389 by HUN
Basically the wierd reason why I'd like to use higher octane is because I don't use my petrol Jimny (or my chainsaw) as often as I used to do. As far as I know the 95 octane petrol goes off within a short period of time (2-6 months depending on storage temperature) causing all sorts of issues with delicate engine components when burns. 98 octane petrol has different additives/component hence it can be stored 'unlimited' time. This is the very same reason why classic cars run on 98 instead of 95.
So I would not mind to use any octane 95 and above if it's not exceeded it's vague 'Best before' date.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 02 Jul 2020 14:35 by HUN.
  • CC Baxter
02 Jul 2020 15:04 #224390 by CC Baxter
Replied by CC Baxter on topic Octane rating behind fancy fantasy names.
The Jimny doesn't need it, all standard Japanese engines were built to run on 95 (Japan runs on 95). Your chainsaw could run on a long life fuel stabilizer which is good for over a year with no gummed up carb.
98 octane offers a more efficient burn but not much else, work out how much more it will cost you and then decide. If you don't burn much fuel then a can of Sta-Bil in the tank might help. As for stale fuel, get rid of it (donate it to a neighbour).
Chris
02 Jul 2020 15:46 #224392 by 300bhpton
HUN wrote: Hi all,
Re-reading your post, I'm a little lost at what you are asking.
In the UK, normal unleaded petrol is 95RON. It should say at the pump and it is typically a green pump.
Some petrol stations will offer Superunleaded. This will have an octane rating in RON of 97 or higher. I think BP Ultimate is 97 RON. While Shell V-Power and Tesco T99 are 99 octane.
In a standard Jimny you need minimum of 95RON but can run higher octane. The higher the octane the more resistance to detonation. Which is handy in high compression engines and turbocharged engines. But it will do no harm in other petrol engines. And sometimes will yield better mpg and if the ECU can adapt, better bhp too, although the latter is in modern turbo charged cars mostly. Most superunleaded fuels also have more additives too, such as cleaners. Which are generally good to run through your engine.
Time to create page: 0.215 seconds
