Wrong snorkel template?
28 May 2020 15:39 - 28 May 2020 18:37 #222933
by HUN
Nope. Just kidding.
I just had more trouble in the last 6 months with my gearbox than others in their lifetime. This week I will fit my gearbox 4th time...after a full reconditioning of the gearbox the input shaft oil seal was leaking. I have replaced all seals every time then refilled the box before went for a test drive. This time I changed the bell housing and input shaft also because I suspect the old one worn or might be damaged somehow? Regardless I'm prepared to take it apart again but with less effort than previously. At least refill will be easier...hence this 50mm hole. Rubber grommet is on the way!
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Wrong snorkel template? was created by HUN
Nope. Just kidding.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 28 May 2020 18:37 by HUN. Reason: Typo..
28 May 2020 22:33 #222958
Replied by jackonlyjack on topic Wrong snorkel template?
This modification is on my to do list
Also going to make chassis gear box cross member removable
29 May 2020 07:40 #222975
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Replied by HUN on topic Wrong snorkel template?
Ahh, that's my dream modification! :woohoo: I wish someone near by could do it for me properly! :blink:
I guess you will need to separate the body from chassis to make a decent weld around the mating plates?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
29 May 2020 10:42 #222978
I have a small body lift so maybe just enough room
29 May 2020 12:41 #222984
by sniper
Make the flange faces so that they fit over the remaining stub on the body side, so a full 360 weld can be done on the internal faces and then grind flat to make the flange face..... That with an external weld to as much of the butt as you can get reach, will be bombproof.....
sniper
Replied by sniper on topic Wrong snorkel template?
HUN wrote: Ahh, that's my dream modification! :woohoo: I wish someone near by could do it for me properly! :blink:
sniper
- X8GGY
29 May 2020 17:56 #222996
Replied by X8GGY on topic Wrong snorkel template?
Hmmm, interesting!
Perhaps you could sketch up a template with reference measurements for others to get the hole in the right place?
