Wheel hole
  • helijohn
14 Aug 2016 16:52 #171303 by helijohn
Wheel hole was created by helijohn
I can't think of a more technical title but what I mean is we all know about stud/bolt patterns and PCD etc. but how critical is the hole in the middle of the wheel. What if it is a bit bigger than the flange on the drum/hub will it it be good enough to be centralised by the wheel nuts? I think I've had some hubs in the past that have not had a lip.
14 Aug 2016 19:50 #171309 by mlines
Replied by mlines on topic Wheel hole
The wheels are "stud centric" rather than "hub centric" so it is important that they are centralised by the studs and not the hub centre.
The following user(s) said Thank You: helijohn
  • helijohn
14 Aug 2016 20:12 #171312 by helijohn
Replied by helijohn on topic Wheel hole
That's good news Martin cos I have some FTO wheels that are the right PCD and offset but have a bigger centre bore. However I just read this a second ago.
Wheel Centre Bore and Spigot Rings Explained:This is the diameter of the centre hole in the back of the wheel. It is crucial that the centre bore of the wheel locates properly on the lip on the hub of the vehicle to get a perfect fit. Most wheels work on a spigot ring locating system because most wheels have a centre bore bigger than the size of the hub lip allowing them to fit a wider range of cars. A spigot ring is fitted into the back of the wheel with an outer diameter the size of the centre bore, and an inner diameter the size of the hub lip to allow the wheel to be correctly located onto the hub and to fit tightly onto the vehicle for safety and comfort.There are wheels that are hub-centric i.e. the wheel is manufactured with a centre bore to fit precisely onto a specific vehicle and in these cases we would not supply spigot rings as they would be unnecessary.If the wheel does not locate onto the vehicle's hub assembly correctly it will cause a vibration on the steering wheel and can lead to bad wear on the tyres and bearings so if spigot rings are provided you MUST use them.
17 Aug 2016 21:45 #171410 by Rhinoman
Replied by Rhinoman on topic Wheel hole
The Jimny wheels don't locate on a flange. I would check the taper on the wheel nuts to make sure that they will be OK when used stud centric.
Time to create page: 0.166 seconds
