Gen 3 rear wheel bearings (ABS)
14 Aug 2022 19:22 #244537
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Gen 3 rear wheel bearings (ABS) was created by Mike G
Hi Martin,
Do you know when you will be getting more Gen 3 rear wheel bearings (ABS) back in stock?
I'm looking to do both of mine and there's only one in stock on the website.
Thanks,
Mike
Thanks,
Mike
15 Aug 2022 08:19 #244539
Replied by mlines on topic Gen 3 rear wheel bearings (ABS)
I can get more which would arrive with you by the end of the week?
- Thank you received: 115
15 Aug 2022 14:42 #244540
by maverick
Jalapeño, IISY?
Replied by maverick on topic Gen 3 rear wheel bearings (ABS)
Time to upgrade to a Fully Floating Rear Axle Converison Kit and use Front Bearings in the Rear Axle
Jalapeño, IISY?
15 Aug 2022 20:28 #244541
by Mike G
Many thanks,
Mike
Replied by Mike G on topic Gen 3 rear wheel bearings (ABS)
That would be great. I tried adding 2 to my basket, but it only allows me to purchase one at the moment. Must be inventory control on your database. If you could let me know when they are back in stock, I'll take two.I can get more which would arrive with you by the end of the week?
Many thanks,
Mike
15 Aug 2022 20:30 #244542
by Mike G
I think the floating axle is great, but the amount of times I'm in the wheel hubs changing a bearing, it's not viable for me. If I was tearing through them, I'd certainly be considering it.
17 Aug 2022 14:01 #244562
Now in stock
The following user(s) said Thank You: Mike G
Time to create page: 0.301 seconds
